| | play in the viscous fan holding on with two bolts |  |
 i have just jacked up front wheels off get ready to clean down and waxoil wheel arches front subframe . the battery light came on and alternator had it so replacing with denso . so on strip down viscous fan out so i can get to replace all belts pulleys and when i took fan out there was a lot off play no wunder only 2 bolts and they wear undun sad old man that could have caused a mess . i would say they wear trying to undo the hub nut on the viscous fan the wrong way as the 4.2 sc is undo anticlockwise could not get it of so undone the 4 bolts that hold the fan on good job the battery light came on as i would not have done the belts etc while  i was replacing the alternator . i must say what a pain the air con silver pipe that goes across the top of the rad i reckon that was designed by a woman if that was not there it would make getting to everything on the front of the engine so simple never mind that is me having a good moan
  new vehicle purchase     |  |     | Click image to enlarge |  2007 supercharged 4.2 java black .sand leather vogue se trim
 previous cars .
 range rover classic 200 tdi
 discovery 1 200 tdi
 freelander 2 2008 hse
 discovery 1 300 tdi
 p38 4.0 ltr man r380 ex royal support vehicle on v5c
 discovery td5 man off roader
