Home > Technical (L322) > L322 Front Diff Recall
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Hello,
I shall be shortly purchasing my first RR (03/53) and I've read about the stripped splines on the prop-shaft into the front diff and the associated recall that was issued.
My question is this, I've seen the pictures on rangerovers.net identifying an original and a modified system and I should be able to tell the difference when I see it but is it possible to see this without removing any panels?
When I go to look at cars if I get under them will I be able to see the diff without removing anything?
Thanks.
Post #59672 10th Apr 2011 5:22pm
Yes
Post #59673 10th Apr 2011 5:27pm
Katash
Thanks
Post #59677 10th Apr 2011 5:43pm
dan_uk_1984
The diff recall is free and any LR garage will do it for you. So if the car hasn't had it done - don't let this put you off.
Post #59679 10th Apr 2011 5:45pm
Katash
Is that unconditional? If I buy one that doesnt have a full LR service history will they still do it for free? I read this which made me worry
Quote:
The program to replace the front drive shaft and drive flange with new parts was technically called a "Service Action" rather than a recall. This apparently means the customer must have the work done within a definite time period for it to be covered.
Post #59680 10th Apr 2011 5:49pm
M44K TS
Mine hasn't got full LR history, I think it's missing a couple of years but LR still honoured it when I took it in to get done last year.
I did ring LR customer services who said I would have to pay to have it done so I wasn't going to bother, but when I actually took the car in for some other work, they told me to bring it back a week later to get it sorted f.o.c. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #59682 10th Apr 2011 6:12pm
Katash
I see, thanks
Post #59683 10th Apr 2011 6:14pm
dan_uk_1984
Where have you quoted this from?
I had my last one done at 110K, at no point did they ask for service histroy etc.
Post #59693 10th Apr 2011 7:15pm
Katash
It is taken from here
http://www.rangerovers.net/repairdetails/d...ecall.html
Its good to know they are still doing it - although after previous experience with my local dealer I think they will try to charge me first tho :0
Post #59708 10th Apr 2011 8:01pm
dan_uk_1984
RR.net is a US based resource. So they tend not to always have information that is relevant to the UK.
What I would also say is that if the car has got to over 75K and the diff hasn't blown then it will not blow. It only ever failed due to misalignment from the factory. Depending if Bob Smith put your front axle on or not. Generally it failed in the first 25-50K.
The diff recall itself has been the cause of a few other issues (drive line vibration, seal leaks etc), so shouldn't be undertaken lightly.
Post #59716 10th Apr 2011 8:50pm
