Home > Maintenance & Mods (L405) > Coolent leak
yelnats69
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zambezi Silver
Coolent leak
I have a 2013 404D Vogue.
It started loosing fluid and has got progressively worse .
Absolutely no signs of a leak.
Oil and coolant clear no drips or exhaust steam, start up fine, idle good engine smooth and powerful. Temp gauge sits at normal.
Coolant no loss on long idle temp on normal.
on the road 1ltr about 2 miles. disappears
My feeling is such a heavy coolant loss would give some tell-tale signs engine wise.
I have been told that the coolant is used on the turbo's or EGR valve?
Any members care to share their knowledge or suggestion or maybe had similar experience.
Post #596912 9th Jun 2021 10:17am
AnotherMutley
My car was losing around 1 litre every 1000 miles, there was no trace of a leak under the car or on any of the under trays. You could definitely smell coolant outside of the car after a long run. A couple of members suggested that it could be that the coolant is being burnt off before it got chance to run down.
Mine had the Thermostat housing replaced twice but the LR dealer then couldn't or wouldn't do anymore to help. It could be thermostat housing, EGR, Oil Cooler, pipe work.
Either of the 2 Indy's posted should be able to help you, they're Indy's and their business model is fixing them not selling new shiney ones, which sadly, is all the Main Agents/Dealers want to do. Unfortunately in Kent/Sussex the quality of dealers isn't that great, I've tried them all over the years.
Post #596916 9th Jun 2021 11:12am
could this be your problem,
https://www.fullfatrr.com/forum/topic48938.html ... - .- -.
Post #596917 9th Jun 2021 11:14am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Stan - I think this only applies to the Vogue SE & AB. I don't think the Vogue has these additional pipes. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #596937 9th Jun 2021 2:59pm
Embarassed Thumbs Up ... - .- -.
Post #596939 9th Jun 2021 3:04pm
