Home > Technical (L322) > Dreaded Suspension Fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34971 |
have a look at the wires on top of the suspension struts...loads on the forum re this. ... - .- -.
9th Jun 2021 6:19pm |
longd Member Since: 24 Oct 2020 Location: West Midlands Posts: 95 |
Popped off the couple of torx and checked the connectors all good !
9th Jun 2021 6:43pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 468 |
Height sensor failure? 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
9th Jun 2021 6:49pm |
Im getting to think that is the fault I'm just reading up on how the system works, I guess ill just disconnect battery measure height of all 4 corners, check tomorrow if all 4 corners are the same then the only thing it can be is a faulty sensor I imagine will go out and play around with the wires connecting it etc |
9th Jun 2021 7:16pm |
GUYS looks like it was just a dirty/ loose connector to the front right hight sensor ! don't want to jinx myself but disconnected batter, removed the sensor cleaned and blew it out and reassembled and no faults and is now showing all wheels level !! thanks so much for the suggestions |
9th Jun 2021 7:46pm |
Well that was short lived, went for a spin fault is back again, I have raised suspension to off road and have disconnected the battery I've measured the height of all corners,
9th Jun 2021 8:26pm |
