Home > Maintenance & Mods (L322) > 2010 Conversion - DIY - Rear Lights/Wheels & Vents Fitte
Page 1 of 3 123>
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
Well the 2010 conversion bits arrived today Smile Really can't wait to get it all fitted. Will be doing it myself, seems to be alot of hush hush about this and I don't really know why..... But hey!
Mine is a 2004/2005 Range Rover Vogue with the touchscreen navigation but the square headlights. So it has pretty much everything I want except the RSE (Another thread to follow on that...). I love the shape of the new cars and after a bit of research into this, I thought I would tackle this myself.
Some very good resources out there, namely the www.l322.com for some pictures. My main concern was the wiring at the rear. This is now sorted and I will have fully functioning lights at the rear working correctly 100%.
A nice extra I have seen is the bumper has the front cameras on it with all the wiring!!! So they will be getting wired in somehow to something though I haven't a scooby how we will achieve that yet.... They are 4 wires on the main loom for it.
Wheels wise, I have some 22" Tigers to go on. I think these will be spot on, though will be finding out on the ride. If not I will drop to some new 20" wheels off the Vogue SE I think...
- The old girl
- 2010 Bits just unloaded
- Bumper with Cam Very Happy Very Happy Very Happy
- New Headlights Brand New
- Wheels 22" Overfinch Tigers.
Watch this space, it will develop slowly and I will hopefully document everything Smile
Then the last project is Rear Screen Entertainment..... If I can source the parts......
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #59105 6th Apr 2011 7:30pm
Someone on the forum is selling 2 rear TV screens I think.... Discovery 4 HSE
Post #59106 6th Apr 2011 7:32pm
my range is the same as yours bigj and this is a kind of thing i would like to do ,so i'll be watching this thread with interest.... ... - .- -.
Post #59129 6th Apr 2011 8:37pm
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
Good luck mate hope it goes smoothly for you. Keep the pictures coming
http://gallery.me.com/paul_harland/100010
Range Rover Vogue TD6 2002 "52"
Bonatti Grey
Post #59133 6th Apr 2011 8:55pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Was your's already upgraded with the navi touchscreen?
Post #59237 7th Apr 2011 11:53am
Paulo
Looking forward to seeing this carried out, major kudo's on DIY..... Thumbs Up
Post #59245 7th Apr 2011 12:29pm
BigJ
No mine already had it from factory. Last of the square headlight models, but has the touchscreen nav in. So I got the BMW engine as well which I was pleased with Smile Used to have:
Now have:
Post #59248 7th Apr 2011 12:52pm
BigJ
So a good day yesterday, I have wheels, vents and rear lights fitted as well as the front bumper painted. Got some walk through here.
Firstly I removed the front vents. Brief guide (Thanks for the ones on here). Pretty much the same except don't remove the lower panel completely, rotate it around and there is enough room. Also a 10mm ratchet spanner is your friend hugely on these!!
1) Lift the bonnet and locate the bolt as shown below. Undo with a spanner, careful of your bodywork.
2) Open the door completely and sharply pull the top half of the panel away, then the bottom half. Rotate it to the left as shown below.
3) Undo the bolt behind here. Once this is done there are no more bolts securing them.
4) Now remove the vent by pulling out and to the right. Also it sometimes helps to open the door to get a better angle.
5) Get your new vent, line up the tabs on the left of the vent inside the whole and weave it into the gap. Again open the door at different angles to align.
6) Once this is done it is fitted.
7) Put the bolts back in top and bottom, tighten the lower one first and then the top one to get the gaps correct. Take your time.
Stand back and admire your work!! Suits bonetti grey so well these, once clean.
Right moving onto the rear lights fitting. Out of interest I plugged mine in directly, no error messages, no fog lights errors at all which was strange. I don't give it long though so i've wired it in correctly. Now to point out here you do need resistors wired inline to the side lights and the indicators due to the LEDs. They require less power than standard lights (This I like to think of my contribution towards my carbon footprint reduction!!!! Laughing ). These will also be required on the front lights too.
Very good link here - http://reviews.ebay.co.uk/Load-resistors-f...0010344226
1) First of all here is the wiring loom for the resistors and relays etc.
2) Open the boot and remove both 10mm bolts with that ratchet spanner.
3) I used a thick piece of plastic and a plastic screwdriver to gently prize the rear light out
4) Unclip the wiring loom, push the two ends together and slowly release
5) Strip out the boot floor, remove the 2 rear covers and undo the 6mm allen bolt and remove the 2 rear carpet inserts
6) By hand remove both the plastic inserts inside
7) Drill the spot welds out on the brackets. Then measure accurately and drill 2 6mm holes into the bodywork
Cool Insert a gromit with a small amount of silicone on the inside into the hole. Careful, you can cut your finger.....! Part number below:
9) Lay out the wiring loom you have made and ensure all wires are straight
10) Cut back the insulation here. Has to be done well, the resistors are mounted here and will get hot!!
11) Mount the resistors in the space you have created.
12) Ground off the resistors onto the 2 handy ground points on either side.
13) Tap into the rear side light feeds and the rear indicator feeds and terminate.
14) Ensure the lights line up nicely and connect and rebolt in
15) Power up the resistors and enjoy your new lights!!
*** I have to add a few more pictures in that. Wiring diagrams to follow once I have done the front end as well ***
Now with a poorly finger it's complete so very pleased. It all suits well, i'm very pleased and that's all what's matters cos it's my Range Rover!!
Quick clean today and fitted the new wheels.
Here is a picture of a few other bits still to fit except the wheels!!
Hope you enjoy the read, it will get bigger. Please only positive comments, if you don't like it..... Tough!! My car my choices.
Last bit.... Reading the map out of the car getting ready for it's final remap Smile
Now have:
Post #59691 10th Apr 2011 6:59pm
Well done looking good , will be following your exploits ..... Thumbs Up Thumbs Up
Post #59695 10th Apr 2011 7:20pm
paul_h_8
Looking good mate so jealous
Bonatti Grey
Post #59697 10th Apr 2011 7:34pm
Martin
Site Admin
Great write up, do keep us up to date Smile
BigJ wrote:
<snip>
Now to point out here you do need resistors wired inline to the side lights and the indicators due to the LEDs. <snip>
Just wanted to clarify this (as it's important) - I think you mean wired in parallel, not inline (series) - from your words it sounds like you've wired in parallel, which is how they should be connected.
Post #59700 10th Apr 2011 7:39pm
daveo
the 2010 looks well with your colour, thats for sure..intrested in the mapping, will that be a performance map or is that to do with the lpg..
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #59703 10th Apr 2011 7:50pm
pretlove
Great right up mate Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #59742 11th Apr 2011 12:54am
BigJ
Thanks for the positive comments guys Smile
Dave - Remap is purely because that's what I do, but the Range Rover seem to lack slightly in the midrange. Throttle response was quite slow as well, sharpen this up to not make the pedal feel as long travel if that makes sense as well as that flat spot from standstill. Also removed the VMAX at 130mph just cos it was there....!
Pleased with it, it's not a massive gain such as the TD6's and the TDV8's but a nice low and midrange gain. Feels easier on the motorway between 70mph and 90mph as well (On my own private runway I have on the estate....). Fuel wise, keeping an eye on it. Runs some more timing in the maps, leaned out slightly on the fuel and a few other tweaks. Overall very pleased. More than welcome to test drive mine, would appreciate any feedback. Used to have:
Now have:
Post #60143 13th Apr 2011 8:46am
daveo
thats great, my mates 2004 4.4 petrol,when he had it was cipped and would leave my one for dust,not sure if it would make a huge difference but i have 22" and he had 20" apart from that they were the same.
would like to get involved in that, only for my own use...
your facelift looks great in that colour, did you ave to change the front bumper iron. Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #60194 13th Apr 2011 6:49pm
Page 1 of 3 123>
