![]() | Home > Technical (L322) > Fans don't switch off. |
chinkoa Member Since: 17 Jan 2014 Location: West Yorkshire Posts: 34 ![]() ![]() ![]() |
The out of the blue the Fan does not switch off.. Could it be a relay? if so where is it and what colour?
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
https://fusesdiagram.com/range-rover/fuses...-2012.html
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8819 ![]() ![]() ![]() |
Another common item is the FSR, search on here, lots of info... Pete
Hi Martin,
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
Was FSR that failed on mine that left fans running all the time even with ignition off and vehicle locked...only a flat battery stopped it! Had to use a key as central locking wouldn’t work. Now have a charger for 13 pin electrical socket. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Merchy and Haylands,
I think the FSR is more common, get a genuine one, the cheap ones don't last many months and are false economy if your fatty is a keeper.... |
I did not realise that the FSR could cause the fans NOT to stop, There was me thinking only about the FSR stopping the fans starting ooooppppssss |
FSR can do all sorts, on all the time, off all the time, wrong fan speed and a combination......
