Home > Technical (L322) > knocking
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
knocking
Got a knocking noise when going over bumps, sounds like its coming from the nearside front, both my lower arms and balljoints have been done. So anything else known to go around the front suspension on these bloody needy machines? 2004 black Vogue TD6
Post #59592 9th Apr 2011 8:52pm
Drop links, ARB D bushes, Track rod ends.
TRE is the most likely
Post #59600 9th Apr 2011 9:31pm
dan_uk_1984
Mine turned out to be the anti-roll bar links. £15 each and an hours labour for the pair...
Post #59605 9th Apr 2011 10:27pm
boffhead
Me too...... ARB links.
Chris
Post #59687 10th Apr 2011 6:32pm
Tesh
ARB drop links...........Just done mine last week
Post #59707 10th Apr 2011 8:01pm
letsavit2
Thanks guys,
did have a look today but couldn't see\feel anything obvious, but when going over a speed bump with just the right then left wheel it did knock both times, so backing up what you guys are saying, the anti roll bar links.
This an easy job? 2004 black Vogue TD6
Post #59715 10th Apr 2011 8:46pm
letsavit2
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWAX:IT
reckon these are too cheap, or do the job?
land rover coming in at 70quid posted for the pair 2004 black Vogue TD6
Post #59782 11th Apr 2011 12:19pm
letsavit2
Censored it, ordered cheap ones, if i get this fixed for 14quid ill be well happy.
Talking to myself here.... Laughing 2004 black Vogue TD6
Post #59799 11th Apr 2011 1:13pm
Reformed
Keep us updated, If these work and are not so bad I could be tempted Smile
Are they easy to do yourself? Reformed
Post #59874 11th Apr 2011 7:41pm
letsavit2
The guy seems to mostly sell links for various cars and i went through a few pages of his feedback and all seem happy with them, ok not a long term test but i could buy the 70quid land rover ones and still have the knocking. At 14 quid i might as well shotgun with cheap parts until its gone.
looks like very easy job compared to the balljoints, well as long as the rusty lower nuts crack before i lose my temper... Laughing , have wire brushed the ends and soaked them in wd40 today. Should be able to do in off road height at full lock without even taking the wheels off...we will see.... Whistle 2004 black Vogue TD6
Post #59905 11th Apr 2011 9:07pm
letsavit2
Thanks guys, drop links it was.
Cheap part looked OK, original had some spot welds on the joins, these didnt, but did come with nylon locking nuts which make sense. Time will tell but for 14 quid thats a cheap range rover fix... Laughing
Easy job, didnt even take the wheels off, 4 bolts done in normal height with wheels at full lock, off road looked to put some tension on the anti roll bar. 18mm extended socket and 18mm flat spanner to hold other side.
for search reference;
At 80k i had;
Front Creaking = lower balljoints, i replaced the whole lower arms with balljoints. parts approx £65 pair. Bit of a pain in the arse job and wouldnt do it myself again. pay the hours labour at the garage
Front Knocking = drop links. easy job parts £14 pair, £70 land rover. half labour at the garage
Thanks again... Thumbs Up 2004 black Vogue TD6
Post #60401 14th Apr 2011 8:59pm
pretlove
the cheap ones should be fine land rover just like to have your pants down arb links should always be around £10 unless you go to the stealer Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #60407 14th Apr 2011 10:20pm
Reformed
Thanks for the info, I am going to get these and change mine myself.
Pretlove, loving the avatar Thumbs Up Reformed
Post #60561 16th Apr 2011 7:27am
