Home > Maintenance & Mods (L322) > Surround Camera Pinouts and Wiring - Any Info?
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
Has anyone got any? I see each camera has a 4 pin output. Can these be powered up at all?
Would love to enable them. I have the 2005 touchscreen DENSO unit. A bit of wiring won't hurt, I have the 2 front cameras..... Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #59719 10th Apr 2011 8:55pm
daveo
hi, i have the full set, 4 cameras plus the rear reversing camera and the video module unit, the 4 pin cameras are HD, do you have the 4 pins plus the video out put... V8 facelift Range Rover Autobiography 22" wheels.
Post #59722 10th Apr 2011 9:20pm
BigJ
Cool yeah got the 2 front cameras only you see.
From what I can see just the 4 pins?? What are each of them? Used to have:
Now have:
Post #59723 10th Apr 2011 9:31pm
daveo
ok...have you got 4 pins and the round MCX plug, its like a mini aerial socket.if you have then you have the HD cameras V8 facelift Range Rover Autobiography 22" wheels.
Post #59726 10th Apr 2011 9:49pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
do you have cameras on the front of your car?? how does that work on a 05??
Have a 06 and cameras in the front would be great!!
Phil
Post #59741 10th Apr 2011 11:32pm
BigJ
Hi Dave,
Yep 4 pins and a round MCX plug check Smile
HUGI - I am facelifting to 2010 spec and the bumper came with the cameras in it already Smile Used to have:
Now have:
Post #59749 11th Apr 2011 7:12am
daveo
i spent a lot of money on my set only to find out i could not use them, all be it they are new but then found out you need can bus to run the system "touch screen and on" the module is the key part, all the cameras come back to the module and ten there is a video out tat goes to the video in on the back of the touch screen, the early cameras were cmos and the picture can be poor and grainy but the later cameras are ccd, far better picture all together
they can be fitted to the newer 2010 cars as an retro fit as the chap at the shooting ground had them added as an extra after he bought his car, £3,000 plus i would imagine the loom is there but on the earlier cars you will have to fit the loom needed. V8 facelift Range Rover Autobiography 22" wheels.
Post #59753 11th Apr 2011 8:10am
BigJ
Are you selling yours Dave?
Assume it uses the MOST fibre loop? Although it will require the newer sat nav systems I reckon. I have the DENSO sat nav touchscreen.....
Wondering if they can go into an aftermarket system at all. Used to have:
Now have:
Post #59754 11th Apr 2011 8:15am
daveo
here you go this is what i got in my kit...
this is the main module
four of the hd cameras
one rear camera
small part of the loom
it does not use optic fibre but does need can bus, i paid over £400. and was hoping some cleaver dicky comes up with a can bus to i bus interface as i cant use it but always open to offers.
if any one is interested pm me
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #59863 11th Apr 2011 6:16pm
