Home > Technical (L322) > Home made gearbox flush 6HP26 automatic gearbox
ur20v
A Trap
Deleted
Post #597331 13th Jun 2021 4:29pm
ur20v
A Trap
Deleted
Post #597335 13th Jun 2021 4:52pm
ur20v
A Trap
Deleted
Post #597338 13th Jun 2021 5:44pm
ur20v
A Trap
Deleted
Post #597344 13th Jun 2021 5:57pm
That's one way of doing it.... Thumbs Up Pete
Post #597370 13th Jun 2021 8:58pm
Ingenius... Bow down Thumbs Up
Post #597389 13th Jun 2021 11:08pm
GraemeS
Australia
Re: Home made gearbox flush 6HP26 automatic gearbox
ur20v wrote:
Note if you do run the oil out, don’t worry, these gearboxes/torque converters self bleed, just don’t run it dry for an extended period. 👍
NEVER run the gearbox without oil. The gearboxes are filled with oil then the pump primed before the gearbox is fitted to a vehicle. Draining the oil for an oil change doesn't drain the pump.
Post #597394 13th Jun 2021 11:24pm
ur20v
A Trap
Deleted
Post #597407 14th Jun 2021 8:07am
GraemeS
Australia
The first component to fail when inadequate oil is in the pump is the seal to the E clutch which shares the same shaft. Unless you're speaking from experience of having allowed the engine to run with nil oil intake even for a few seconds then IMO you shouldn't be advocating that no damage will be done by doing so.
Post #597416 14th Jun 2021 8:52am
ur20v
A Trap
Deleted
Post #597431 14th Jun 2021 10:49am
ur20v
A Trap
Deleted
Post #597585 15th Jun 2021 12:44pm
How big is that catch tank/receptacle/bucket thingy please, save me measuring the box beforehand..?
Cheers Thumbs Up Pete
Post #597604 15th Jun 2021 2:39pm
ur20v
A Trap
Deleted
Post #597610 15th Jun 2021 3:15pm
ur20v
A Trap
Deleted
Post #597611 15th Jun 2021 3:16pm
kbald
Brilliant idea and well explained. Just to check did you flush through with zf6 atf and I presume it's junk and thrown away when both flushes have been done?
Also if you do this what amount would you need approximately to refill the gearbox as just dropping the pan is normally about 7 litres I believe. Thanks Current 2007 TDV8 Vogue Buckingham Blue
Post #597645 15th Jun 2021 8:33pm
