Home > General > Gearbox and engine fault?
hongkongphooey
Isle Of Man
Hello chaps,
Familiar story unfortunately. I just sold the td6 and bought an 06 4.4v8 petrol. I've left for work in the states and the car was running fine until I got an email from wifey saying, I've got a warning on the new car.
First one was, transmision fault, limited gears only. Then when she left the in-laws, it gave engine fault and left the yellow engine light on?
So is the gearbox screwed or is it maybe a battery issue?
Any thoughts would be much appreciated,
Phooey
Post #59757 11th Apr 2011 8:52am
hongkongphooey
Isle Of Man
Any early thoughts would be helpful as I'm about 3000 miles away, and if it's terminal I'm just going to dump the car with the dealer, I've not the time nor the patience on this unfortunately. Sad
Post #59759 11th Apr 2011 9:20am
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Don't dump it at a dealer take it to here:
http://www.independentlandroverservices.co.uk/
Post #59764 11th Apr 2011 9:56am
hongkongphooey
Isle Of Man
That looks local Smile are they anything to do with K-Motors?
Them boys are in Preston. Can you recommend these people?
I'm going to get the wifey to call the AA in to check the Battery condition first. If it's OK, dealer can have it back, it's within the 3 months. In fact I only bought it about 2 weeks ago!
Post #59766 11th Apr 2011 10:09am
nbunney
No they are nothing to do with K Motors.
The mess K Motord made of my mates SC over 3 months I would not take a skate board to them.
Independant Landrovers in Preston, as per link, had it for 24 hours, fixed the fault / repaired K Motors mess and fixed an extra sensor fault for less than K Motors charged for labour Whistle
Post #59767 11th Apr 2011 10:24am
nbunney
Not Brock was it Whistle
Post #59768 11th Apr 2011 10:25am
hongkongphooey
Isle Of Man
No, it was an Indy down in Leicester. I'm hoping it's just the battery, on the drive home there wasn't a whiff of bother or any indication of trouble. Then the car was left for about 4 days and the faults popped up, gearbox one seems to have just been transient, just engine system fault remaining now?????
Not much I can do until I'm home.
Cheers anyway mate.
Post #59872 11th Apr 2011 7:17pm
Vogue
sounds like a battery related issue to me, i'd stick a new battery on anyway - cars are often left on a dealer forcourt with flat batteries for weeks, then when sold they are knackered and can only hold a limited charge.
I had mine tested and it read ok, but it was goosed. A new battery sorted it. For the sake of £100 odd quid I'd eliminate the battery first - and claim it back off the selling dealer. Or get them to pay for it in the first place, its a cheaper first option for them than calling them or another garage out.
Post #59965 12th Apr 2011 9:51am
hongkongphooey
Isle Of Man
Yup if I were a gambling man I'd say battery. Bit of an update, had the father-in-law put a multi-meter on the battery to see if it was anything obvious, 12v resting and 15v with the engine running Shocked
Maybe that was just after starting??? but 15v seems a tad high, I'd have expected more like 13.5ish. Anyway, after 3 days of light use, amber engine light check has gone out. No lurching or noises, no temp issues, so fingers crossed it was just due to inactivity. I'll have it serviced and a good once over when I get back for peace of mind. May even treat the old girl to a battery Smile
On a lighter note, i'm over in West Palm Beach, so I've filled my suitcase with lovely Meguiars car kit. After reading so much about it, I thought I'd give it a try and Wal Mart are selling it cheap.
Pictures to follow gents when I'm home and the cars looking all gleaming!
Thanks a lot for the input.
Post #60044 12th Apr 2011 4:35pm
noddy5vogue
United Kingdom 2003 Range Rover Vogue Td6 Java Black
You wouldnt be doing much polishing today 23 degrees here in blackpool today!
Post #61244 21st Apr 2011 8:29pm
hongkongphooey
Isle Of Man
Got back yesterday, can't believe the weather, sunny Blackpool is actually starting to live up to it's name, though it was pretty fine all the way up.
PS You wouldn't happen to be called Mark would you Noddy?
Post #61284 22nd Apr 2011 4:27pm
gl
Sweden 2011 Range Rover Autobiography TDV8 Bournville
i had that problem this winter but i just turned of the car and restarted it and then it was no problem. 2011 tdv8 autobiography bournville / Arabic
2012 tdv8 autobiography orkney gray / jet/jet waiting
Post #61554 26th Apr 2011 9:50am
