|  | Home > Technical (L405) > Rotary Gear Selector issues |
| AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400    | Only from D4 experience, have you tried getting a can of compressed air and firing it around the gap between the knob and shroud. I keep my cars very clean, however, I was surprised by the amount of dust that came out of my switch are 18 months.
|  1st Jun 2021 7:52am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880    | the rotary gear selector is used on the later L322's so a forum search might help.. ... - .- -.
|  1st Jun 2021 9:24am |
| GB78 Member Since: 03 Dec 2019 Location: Essex Posts: 70      | It is definitely locked in position as opposed to stiff to turn.
|  1st Jun 2021 9:28am |
 Ok thanks, I discounted the search results as they were all L322. I presumed the L405 would be different.   | ||
|  1st Jun 2021 9:30am |
| Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608      | It could be a solenoid issue on the mechanical release mechanism? We had this on our D4 and it eventually locked completely. I replaced the unit myself and has never given a problem since  | ||
|  5th Jun 2021 8:45pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | More likely the solenoid than the switch I would think. If it’s working most of the time it might be worth a squirt of something to free it up and get a few more months out of it.
|  6th Jun 2021 9:27am |
| GB78 Member Since: 03 Dec 2019 Location: Essex Posts: 70      | Aaargh!!! Bloody thing got itself stuck in reverse for the Mrs. It wouldn’t move to any other option. She turned the car off and now it won’t start as still in reverse. AA on the way   | ||
|  16th Jun 2021 7:42pm |
| GB78 Member Since: 03 Dec 2019 Location: Essex Posts: 70      | Oh and I forgot to mention it is partially blocking the cul de sac as it happened reversing off our drive   | ||
|  16th Jun 2021 7:45pm |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3887      | Try selecting high and low range a couple of times and then re try the selector dial.
|  17th Jun 2021 7:38am |
| GB78 Member Since: 03 Dec 2019 Location: Essex Posts: 70      | So....  After lots of head scratching by the AA bod he eventually figured out that the FF wouldn't move even after the manual neutral release was pulled because he forgot to release the parking brake   | ||
|  17th Jun 2021 3:04pm |
| GB78 Member Since: 03 Dec 2019 Location: Essex Posts: 70      | So an update.....
|  23rd Jun 2021 6:59am |
| Posting Rules
 Currently at the dealer waiting for a new gear selector, amongst other things
