Home > Technical (L322) > Annoying squeak near side front.
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
So this old cart is now sounding like a western carriage.
For her age I know the feeling at time but finding this has been rather expensive, thought it was bush on the lower arm but alas not, so I went all out and changed the damper/airbag/strut, the other lower arm, ball joint on the hub and anti roll bar link.....and it's still sounds like a western carriage on rusty leaf springs.
The anti roll bar bushes are poly.
Ideas to look for...
I'm now thinking the CV or ball joint on the rack but can't see it really as these seem fine.
I've done extensive searching on here hence the way I went about finding the critter squeaking.
https://drive.google.com/file/d/1xYGusIGwb...p=drivesdk
This clip is the raising to off road height
https://drive.google.com/file/d/1xXDPOYwsl...p=drivesdk If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #597734 16th Jun 2021 8:51pm
Should be all fixed by the morning as its raining tonight sir Very Happy Thumbs Up
Post #597755 17th Jun 2021 1:43am
kevinp
Rolling with laughter
Post #597762 17th Jun 2021 6:28am
Welshdragon
πŸ˜‚πŸ˜‚
Not here in Wales....for a change! If it dont work.......burn it!
Post #597807 17th Jun 2021 1:59pm
Welshdragon
πŸ˜‚πŸ˜‚
Post #597808 17th Jun 2021 1:59pm
Welshdragon
Well after 20 minutes of raising and lowering the FF and crawling under it while all the joints, arms and bushes rechecked, the critter was found.
The cart spring sound that we all have had from time to time, this is a new one on me......the top small ball joint on the sensor arm was dry and vibration was felt through the arm to the lower suspension arm.
So what's the morale of all this.......if you think its a bush that's squeaky...check the sensor arm firstπŸ€”πŸ˜‚
Post #597810 17th Jun 2021 2:13pm
That picture is the ARB drop link...!! Pete
Post #597832 17th Jun 2021 6:19pm
Welshdragon
Pete,
No its not the link your talking about is brand new and shiny!
this it the sensor to lower arm....you can just see it in the picture at the bottom.
Its the original sensor too. If it dont work.......burn it!
Post #597843 17th Jun 2021 7:57pm
Ah, OK, sorted.. Thumbs Up Pete
Post #597850 17th Jun 2021 8:49pm
