Home > In Car Electronics (L322) > Using Rear Camera feed for Screen Mirroring
Sonearly
I am researching the option of using the video feed used by the rear parking camera to allow the mirroring of a phone screen enabling the use of map apps etc. The principle seems sound, with a switch used similar to that used by selecting reverse gear. I could be dreaming but it seems achievable especially if GAP could do some trickery with the Navigation switch. After all the Navigational system is not the best and personally not worried if it became defunct. Obviously it would require a box to covert the screen image to an AV output which are readily available. Just seems a possible cheap option utilising the existing screen.
Post #597960 18th Jun 2021 9:54pm
Be a bit inconvenient to reverse everywhere... Laughing Pete
Post #597962 18th Jun 2021 10:55pm
mjdronfield
Backwards is the new going forwards Pete Rolling with laughter
You could maybe have a video switching unit so you could choose between feeding from the rear camera or the screen mirroring....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #597963 18th Jun 2021 11:05pm
p38arover
Australia
You need a switch to supply 12v to the same switching input that the reverse signal feeds. It would need a diode in the reverse line so that the reverse lights weren't illuminated when the switch is operated.
I've been thinking of doing it to mine.
On mine (2003), the TV module had a video input that wasn't used. It also has an input terminal, which, when supplied with 12v from the reverse lights, switches that video input to the TV screen. I connected a camera to the unused video input to give the car a reverse camera. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #597976 19th Jun 2021 7:18am
Sonearly
I’m looking at solution for 2011 system, I am assuming when you select reverse the “system” sends power to the rear camera which in turn sends feed to the head unit and switches camera view on. Need to understand where the video feed input process is activated. Anyone have details what each input socket on the rear of the unit is for.
Post #597991 19th Jun 2021 9:17am
mjdronfield
The Workshop manual and the electrical diagrams are available for download in the Wiki.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #597994 19th Jun 2021 9:43am
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #597997 19th Jun 2021 10:21am
Sonearly
Many thanks for info, looks like fallen at first hurdle, was hoping head unit received instruction from camera feed. Only option would be if instruction from TCM could be duplicated somehow, well beyond my capabilities, perhaps GAP may have solution to duplicate/replicate message to head unit.
Will look at wiring diagram to see if dedicated circuit/wire in loom from TCM is camera prompt. Perhaps we have a wiring expert that has the answer.
Well looks like Brodit mounted option after all.
Post #598006 19th Jun 2021 11:44am
GraemeS
Australia
If your vehicle has surround camera fitted then the camera feed to the monitor can be intercepted at the surround camera module which is located under the front passenger seat and accessed from behind the seat. I fitted a video switch between the monitor feed from the surround camera module that provides 2 alternate camera inputs. Selecting camera from the main menu causes either surround camera input or one of the other cameras if switched.
Post #598010 19th Jun 2021 12:05pm
mjdronfield
I suppose it’s not possible to change the config of the car with IID tool to tell it that Surround Cameras are fitted.... and then feed into the loom where that module was?
Prob still need can bus signals though....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #598012 19th Jun 2021 12:29pm
GraemeS
Australia
The surround camera module's feed to the display connects to the same video input on the display as a single reversing camera, so nothing special as far as the display is concerned. Using the surround camera module's feed at the surround camera module might only be a more accessible point to which a video switch could be fitted.
Post #598019 19th Jun 2021 1:18pm
i looked into this a while ago and from memory i found that you need a video integration interface and connected to that a multimedia unit or a mirroring module .. ... - .- -.
Post #598044 19th Jun 2021 4:29pm
Sonearly
Using the surround camera route seems feasible, the video feed is relatively easy as you are just replicating what is sent from a camera. Just need to see how easy it is to retro fit module, need to see if the wiring is already part of the loom.
Post #598054 19th Jun 2021 5:51pm
GraemeS
Australia
The presence of the surround camera module only provides a convenient connection point, probably saving having to get to the back of the display to plug in a video switch. The video cable for a rear camera only vehicle runs the full length between the display and the camera whereas when the surround camera system is fitted the video cable only runs from the display to under the left front seat in my RHD vehicle.
Why not use the companion camera input instead of the reversing camera feed? It's a 2nd video input on the display. My vehicle doesn't have a companion camera and is probably why there isn't an option on the display to select it, not being enabled in the CCF.
Post #598094 19th Jun 2021 10:24pm
mjdronfield
You mean like the venture cam?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #598103 19th Jun 2021 11:53pm
