![]() | Home > Maintenance & Mods (L322) > So what’s this then? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871 ![]() ![]() |
air storage for the suspension.... ... - .- -.
Clobski Member Since: 21 May 2021 Location: Guildford Posts: 30 ![]() ![]() ![]() |
Cheers Stan.. any ideas if they are easy to replace??? |
not personally but a forum search or perusal of the WM might give you some idea... ... - .- -.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
Some have replaced them, but they are a pressure vessel, so if it’s not leaking and the suspension is working then a quick clean up and repaint should suffice. There is nothing that can't be fixed with a hammer😜😜
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351 ![]() ![]() ![]() |
If it ain't broken then don't fiddle |
Thanks Dr Rob.. it’s just that as I was spannering off the side steps I kept brushing against it and it felt like paper mashe!!!.. I just remember having an MGB GTV8 a few years ago that had stainless sill guards.. when I took those off the lower body underneath felt the same and was rusted through. |
I see you’re just up the road from me. Happy to help with anything local e.g. I use www.glenrands.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Fantastic.. thanks Rob.. just about to book myself onto a days worth of off-road training on Hankley Common.. which is just up the road from you.. so bound to need some advice after that.. appreciated 👍🏻 |
bluebottle Member Since: 16 Apr 2021 Location: The M3 Corridor Posts: 157 ![]() ![]() ![]() |
Ah, another nearby. Any chance of organising a working meet where us new FFRR owners can get some assistance in the little jobs we all should be doing, like sill and rear wheel arch protection?
I change LOTS of them that rust through and cause brake downs! Early early cars had aluminium tanks and then JLR decided to change them to steel! So, the moral of the story is... If it feels REALLY REALLY rusty then change it before it leaves you stranded sir ![]() |
Yes good call Mr Craig.. will have a gentle poke.. will I need any special kit.. ie is it a diy job? 2010 RR 4.4tdV8 Autobiography
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Working under a vehicle, especially with rust particles flying around - ALWAYS use eye protection.
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547 ![]() ![]() ![]() |
I did mine on the drive. Wasn't too bad though I recall being a bit confused by whatever set of instructions I was following. There is high-pressure air involved so make sure you de-pressurise the reservoir safely (I used my IID Tool) and make sure you support the vehicle on axle stands securely. Access to a couple of the bolts was a little tricky IIRC but overall it's a pretty straightforward job. 2016 Skoda Octavia VRS Estate
