![]() | Home > eBay & Bargain Spots > Amazon Prime day deals: Noco |
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 ![]() ![]() ![]() |
If anyone is looking for a compact jump-starter, Noco models are all quite well discounted on Amazon Prime day today and tomorrow.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Great unit, plenty of punch to start our big diesels or act as a power supply. Good quality. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7930 ![]() ![]() ![]() |
I’m tempted by the GB70......
good shout on the gb70, I was only looking at the 150. Just ordered a 70 |
I’ve bought a GB70.... and a case for it.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1366 ![]() ![]() |
So you dont get a mains to 12vdc charger with this? 2018 SE SDV8 4.4 Byron Blue |
So how can a 5VDC USB device charge the 12VDC booster? 2018 SE SDV8 4.4 Byron Blue |
Beats me how it works, you need 14.4v to charge a 12v battery. If the charging circuit can boost 5v to 12v at the cost of reducing the current then it’s possible, if not overly practical as it will take a long time. Hence the stated charge time they give of about 12 hours to charge over USB |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
USB is 5V, the jump starters have multiple lithium cells of lower voltage than that. |
So........... has anyone used a NOCO unit on an AGM battery?
Think I’m good, just read the manual and it said lead acid batteries only. Had a panic thinking I have AGM.... but looks like that’s still classed as lead acid.....
Yep works on both AGM and basic lead acid batteries 👍 |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 296 ![]() ![]() ![]() |
Mine has just arrived |
Still charging mine up....
