Home > Maintenance & Mods (L322) > Air Conditioning compressor O rings
Balloonengineer
Does anybody know the part numbers or sizes for the A/C compressor ports?
The ports measure 18mm OD and 15.3mm OD
I would buy an assorted box of HNBR, but it would be good to know what sizes as O rings are as they usually listed by the Inside Dimension, and otherwise I could end up with a box that doesn't fit.
Its a 2004 TD6 diesel L322
Many thanks
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #598185 20th Jun 2021 7:42pm
I bought a generic box for my old fatty, all the ones I needed where there... Got it from Screwfix IIRC Pete
Post #598202 20th Jun 2021 10:59pm
Balloonengineer
Thanks, I just checked at screwfix. They do the basic nitriles ones, but they don't do the green HNBR ones compatible with the refrigerant
Any other ideas?
Best wishes
Post #598204 20th Jun 2021 11:28pm
Merchy
Something like the below link may help HNBR for A/C work.
https://www.googleadservices.com/pagead/ac...amp;adurl=
Post #598218 21st Jun 2021 6:47am
Mine are the green ones... maybe I got them somewhere else.... sorry... Pete
Post #598226 21st Jun 2021 9:14am
Merchy
Just a general caution, whilst some makers do colour code different types of 'O' rings, as per materials / application or use , this is not universal. In my line of work we get Viton, nitrile, HNBR and other types of 'O' rings / seals in a multitude of colours - Always go for the correct material required for a specific application, do not rely solely on the colour. 'O' rings / seals are simple parts, but this can become a minefield to the uninitiated.
Hope this helps. Thumbs Up
Edit, just re-read my post, this is not a comment on Haylands post, as the aforementioned gentleman obviously knows his onions. Just a general comment folks.
Post #598234 21st Jun 2021 10:23am
Balloonengineer
Thanks for the ebay link, but sadly none are the correct dimensions.
Does anybody have a parts catalogue?
Best wishes
Post #598237 21st Jun 2021 10:46am
Merchy
Have a look at the below link to Advanced Factors, one of the site sponsors, a quick call to them should sort you out. Can't see the bits you are after, but it looks like they do all the bits. Or one of the other sponsor suppliers.
https://www.advancedfactors.co.uk/air-cond...1750-c.asp
Post #598240 21st Jun 2021 10:58am
