Home > Technical (L322) > Desperate need for the intank fuel pump
packkratt
United Kingdom 2007 Range Rover Autobiography TDV8 Java Black
I have a 2007 Autobiography 3.6 TDV8
won't start, and fuel pressure is <2psi on the bleed valve, I pulled the pump from the tank and accidentally broke it, not a problem I suspect its duff anyway.
Except no one has stock of the unit, not even land rover, I also called a few breakers,
Does anyone here have a spare fuel pump from the tank, either the whole assembly or just the electric pump from inside the swirl pot?
Any help would be appreciated
Post #598277 21st Jun 2021 3:29pm
rjff
I know it's not much help yet, but what, exactly, did you break?
There might be someone on here who can help with ideas or bits. Cheers
Richard
Gap IIDBT
Post #598286 21st Jun 2021 5:46pm
packkratt
The pipe nipple on the actual pump, I still think the pump is no good, very low pressure and the truck won't start, but I am past the point of being able to re-assemble and let someone else take over 😂
Post #598287 21st Jun 2021 5:47pm
rjff
Somewhere on here, IIRC, is a thread where a member has found a suitable replacement pump unit (just the pump bit, not the whole pot etc) which can replace the one you have.
It may take a while to search, and due to someone parking a b****y great ship in the way delivery may take a bit.
Worth a search Cheers
Richard
Gap IIDBT
Post #598289 21st Jun 2021 6:10pm
packkratt
Great tip, I was trying to figure out a replacement, but finding one that fits and is 0.5 bar seems tricky, I'll search there.
The guy at Pentland land rover said it was because of brexit, but probably that combined with the issues at the Suez.
There is one guy on ebay selling a brand new one at 3x retail (as in dealer retail) criminal!!
Post #598299 21st Jun 2021 6:42pm
rjff
Been rootling about so have a look at this thread:
https://www.fullfatrr.com/forum/topic55618.html?highlight=intank
Wayneg's post, fourth in, has info on the pump he sourced. May not be the same as yours, but fair chance there will be something similar.
https://www.aliexpress.com/item/3282411991...4c4duvodRB
Also Johnsd1v8 on the 9th post bought a cheap replacement complete unit, may still be available
HTH. Cheers
Richard
Gap IIDBT
Post #598380 22nd Jun 2021 3:07pm
packkratt
Just to close this out,
I found a used assembly not far from here, put it in this morning and still wouldn't start, 240kpa is on the high pressure side, started to think it was the hp pump.
Anyway, long story short, I remembered the Aa guy trying "quick start" (forgot to mention this happened after I changed the Fuel filter) so I tried again but this time I used qs in both intakes, after some cranking it fired right up
So, it wasn't the pump (Aa guy was wrong) and I must have somehow got a lot of air into the hp side, even though the land rover manual says just bleed the LP side.
So if it won't start after a pump or filter replacement, try quickstart
Post #598450 23rd Jun 2021 12:22pm
rjff
Glad you got it sorted. Thumbs Up Cheers
Richard
Gap IIDBT
Post #598470 23rd Jun 2021 3:30pm
