Home > Technical (L322) > Ventilated seat
kin
England 2006 Range Rover Vogue TDV8 Zermatt Silver
Ventilated seat
A question to those with vent seats. With the recent hot weather, I finally had the chance to test my cool seat function properly, turned it on full, the seat base cushion felt cold Thumbs Up , but the back cushion seemed normal.
Is that normal? Or should I take it to LR dealer to get it checked?
Post #5969 2nd Jun 2009 10:37pm
Snob ............ Rolling with laughter Rolling with laughter
Post #5980 3rd Jun 2009 11:52am
Larry
England 2006 Range Rover SE Td6 Java Black
Freezing your nads can harm your sperm count! Very Happy
Post #5981 3rd Jun 2009 12:25pm
Paul J.
My seat did the same when used during the recent hot spell, i.e. cold base / normal back. I even switched off the base so that just the back would be cooled but it still didn't appear any cooler.
When I have used it on cooler days (to test it) I noticed that both the base and back were cooled. I wonder whether the effectiveness is reduced when the aircon is working hard to cool the rest of the cabin?
Paul
Post #5983 3rd Jun 2009 12:58pm
Re: Ventilated seat
Ah well Kin, just have to do what some of us mere mortals do .........
Sit forward with the window open ............... Bow down Bow down
Post #5984 3rd Jun 2009 1:08pm
kin
Damn... you caught me. I was really making everyone here aware that I have vent seats in my Rangie.. Very Happy
Seriously, it was a genuine question.
Post #6004 3rd Jun 2009 10:06pm
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
The cooling on my seats only extends part way up the back to about kidney level, I do not think they are designed to cool the whole back.
Note you can toggle between base only and base and back by pressing the button on a cooling or heating cycle. 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #6074 8th Jun 2009 7:36pm
kin
I tried my vent seat again today with just the seatback turned on, turned my radio off, and air-con off. I could clearly hear fans spinning inside the tophalf of the seatback, could feel a tiny breeze coming out of the perforated leather, but not cooled air Confused
Could anyone on here with vent seats try my method, and see if it does the same thing?
Post #6161 14th Jun 2009 6:40pm
wardpg
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
What we do for science just been out and frozen me k******s off.
Your right the back just seems to blow air but when you have the bottom on that gets cool - maybe its to protect our friends across the pond so they don,t claim off LR for cold kidneys!!- mind you they might claim for frozen k******S!!
Post #6163 14th Jun 2009 8:46pm
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
Glad I found this reply as I have the same experience so it seems to be fairly normal behaviour. Seat cooled well but back rest seemed not to work at all. After stopping I could feel a slight air current coming through the back rest with my hand (also only about half way up) but not enough to feel it on my back. I did have the air con up high, however. Perhaps I need to try driving for a while with the seat cooler on but no air con. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #194961 18th Jun 2013 6:07pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
The cooled seats are cooled by peltier systems and are not linked into the AC system, and contain units for seat base and seat back.
Pretty sure mine cools halfway up my back too
From Topix:-
Quote:
Both climatic front seats contain two Peltier cells; one in the cushion, one in the backrest. The Peltier cells are able to deliver heating and cooling based on a voltage provided by the control module. Each seat also contains a fan, which blows air over the Peltier cells to distribute heating or cooling throughout the seat. The Peltier effect occurs when an electrical current is passed through a junction formed by two dissimilar conductors, creating a heat pump. A heat pump absorbs heat from one side of the system, causing it to cool, and then transfers the heat to the other side, causing it to warm. The cell is capable of cooling the incoming air by approximately 8°C (12.4°F), which means that temperature output will depend on the ambient temperature inside the vehicle.
Post #194968 18th Jun 2013 6:32pm
RR2008HSE
Mr Kin,
I've also got the cooled seats and they work exactly as you describe (2008 NAS V8 petrol HSE). I've only had it a year, so I assumed it was normal. (I was actually rather shocked that I HAD cooled seats, as I didn't know they existed before purchasing the car. The original owner was very good at checking the option boxes. Very Happy )
Post #195064 19th Jun 2013 4:38am
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
+1 for 'fart distribution system' Rolling with laughter
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #195068 19th Jun 2013 7:16am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
seriously
when temps are >30 degrees, you want the cooling to work.
My FFRR went into the dealer today - cooling in seat back was not working - but cooling in seat bum bit was working fine.
Dealer informed me there was no cooling in the seats themselves (ahem....) and that the only cooling came from the seats drawing air from underneath the seat.
if i wanted more seat cooling, i had to turn up the air con, and direct it into the footwell.
I suspect I will be writing to Gaydon soon.
Post #199270 17th Jul 2013 7:47pm
Rotorboater
I don't think my seats get that cold but I don't get the wet back of my shirt that I got on my old one without the cooled seats so it must be doing something.
Post #199278 17th Jul 2013 8:07pm
