![]() | Home > For Sale & Wanted > [Wanted] 4.2 SC Gearbox |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16344 ![]() ![]() ![]() |
I changed one recently David… I put a 2008 RRS SC ZF6 into our 2005/6 4.4 NA AJ V8… The only thing I could find different was the electric brain part in the box… (the bit your loom plugs into)
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3282 ![]() ![]() ![]() |
Thanks Craig,
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1836 ![]() ![]() |
As discussed David, all mechatronic units are the same upto end of 07MY and change for 08MY
Just come across this on eBay:
Did see that. They obviously have a different opinion of low mileage |
I saw the advert and was hoping for one around 60k… kinda lost interest when I saw that. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Replacement gearbox purchased.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8657 ![]() ![]() ![]() |
Then the fun starts. Is it coming with the TC? Don't forget to flush out the cooler and lines or change them... I take it you will get it on the ramp to change the box... be a nightmare otherwise... Pete
Yea, it's coming with a torque convertor thankfully as I don't know what crap will be in mine.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2236 ![]() ![]() ![]() |
I don’t get what went wrong didn’t you do an oil change and it was golden earlier in the year and now it’s self destructed since then? Current stable:
I put new solenoids in it as there's a lot of info on the net about them failing at 120 odd thousand miles, I replaced the bridge seal and the 4 rubber dowel seals and I then replaced the sump and filled it with fresh Lifeguard 6 oil that I got from Rob at Duckworths.
That’s a sad tail mine is at similar mileage did the lifeguard and filter last year not done the solenoid I will leave the for the time being I think Current stable:
I reset the adaptions on mine after I’d done the solenoids, after reading online it appears that might have been my downfall. 🙄
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2695 ![]() ![]() |
After you reset the adaptions, did you go through the somewhat lengthy process of getting the gearbox to relearn the adaptions? I had reset adaptions on my 3.0 D4's 6HP28 many times to overcome delayed take-offs caused by light throttle driving without doing a relearn. |
