Home > Maintenance & Mods (L322) > wax oil the front end today of the 4.2 sc
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
wax oil front end today so all back end done so getting there 8 ltrs mud covers all out bad parts was right up in the top of the air suspension bags just a little rust . the last owner spent a lot of money on her so well worth just finishing the bits that will make it last . all fixings i have put back have all been stainless steel even the spire clips nice to go back and remove with ease next time round . and all the gromits in side the arches have been sealed around with pu sealer be for wax oil application belt and braces job as all ways
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #597261 12th Jun 2021 9:43pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Looks a great job 👍
To be honest I have just paid the local truck wash to steam clean all the Waxoyl off the chassis of one of our other cars as I was fed up getting covered in the stuff every time I carried out maintenance.
I use Lanoguard which is lighter than waxoyl and has better creep and self repair qualities.it’s also opaque so that you can see what’s happening to the metal underneath.
Jim
Post #597285 13th Jun 2021 9:59am
oggy
fitted mud guards back and painted callipers
put guards back to day nice new stainless steel fixings and painted the callipers put the new brembo decals on tomorrow just put a order in to opie oils for diff oil and transfer box oil gearbox has had a full flush so all good so far wear next to go or start running out of jobs body work next nice good power cut and polish will bring her back to what she was
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #597531 14th Jun 2021 8:35pm
DrRob
jim4244 wrote:
I not use Lanoguard which is lighter than waxoyl and has better creep and self repair qualities.it’s also opaque so that you can see what’s happening to the metal underneath.
Jim
Got any pictures of it? I'm keen to learn more about it. Does it stink of sheep? Lanolin content Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #597564 15th Jun 2021 9:39am
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Ive just used lanoguard and the smell isnt as strong as waxoyl. Once dry it leaves a waterproof satin sheen which looks really good. It also goes a long way as its thin (watery) and easily applied with a hand sprayer. a little goes a long way. also, once dried the smell is minimal.....I've never got up close to a sheep to smell one to be honest
Post #598577 24th Jun 2021 11:24am
jim4244
Dr Rob
I’ve just treated my 90 with Lanoguard after first treating with Aqua Steel rust converter.
Here’s a few photos
Simple to apply. You simply spray it on using a spray bottle. It dries a nice opaque/clear and is dry to the touch, so you don’t get covered in black if you work on your car.
The smell is noticeable for a couple of days. Just stay away from fields full of Rams……….
Jim
Post #598578 24th Jun 2021 11:35am
nambFFRR
.....I had a few dogs run after me!
Post #598581 24th Jun 2021 12:16pm
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
On hot days the smell comes back a bit.... 2011 Vogue SE TDV8
Post #598583 24th Jun 2021 12:55pm
nambFFRR
did mine 2 weekends ago and its not smelly anymore....its 23degC here today and I cant smell anything particularly nasty. Waxoyl on warm days tends to 'leak' and drops spots on the floor
Lets see if I can smell anything going forward
Post #598589 24th Jun 2021 1:36pm
oggy
if you use the car plan tetrosyl wax oil there is very little smell the hammerite one stinks bad get the first coat on one day and give it a second coat next day when you can not see any washers you no you have a nuff on and once a year for a recoat new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #598612 24th Jun 2021 7:30pm
