Home > Group Buys > Heated / Cooled Seat Unit Repair Kits (Group Buy)
Page 1 of 4 1234>
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I am looking into a potential group buy of the heated cooled repair kits.
The more we can buy the cheaper we can get them.
We will also be offering a repair service (you send us your faulty unit and we assemble and send back) and drive in service if local.
If anyone is interested let me know, will make a list and get a price table together.
1-SoggyBottoms (PAID)
2-RRDunc (PAID)
3-RichTD6 (PAID)
4-Ansi (PAID)
5-Tinman (PAID)
6-TDV8 Paul (OUT)
7-t5pete (PAID)
8-Discotigger (PAID)
9-jonty88 x2 (??)
10-jambo27 (NOT YET PAID)
11-Robert (??)
12-Sarchopperman x2 (PAID)
13-Saxymark (??)
14-Quiff (PAID)
Post #598461 23rd Jun 2021 2:03pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
count me in
Post #598463 23rd Jun 2021 2:19pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
I'm about to take my car back to the garage that I bought it from for some warranty work. If they don't fix my front seats then count me in!
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #598505 23rd Jun 2021 7:54pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Count me in please Thumbs Up 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #598545 24th Jun 2021 8:06am
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Count me in for the duct. Mine, (the one in my seat) Embarassed, just broke again.
Post #598605 24th Jun 2021 5:09pm
JNC
I've repaired mine 2 or 3 times this year trying various methods and I think its started to go again.
That's what has prompted me to look at alternate options.
Will get the ball rolling with this early next week.
Once I get 5-10 pre orders, will get landed price and confirm those still happy to proceed, we will then get an order placed.
We will probably order 20 or so for our own stock which will be sold at normal price.
Post #598626 24th Jun 2021 9:11pm
garyRR
Out of curiosity, what fails that you have to repair?
My driver's seat was not heating and the cooling was only working on the seat base. The passenger seat was working. I also hoped it would resolve my steering column position sensor / memory but this remains the same.
I replaced the seat ECU with a used ECU. Seat heating started working but seat cooling stopped working, as did heating of the passenger seat.
My next port of call is probably a brand new seat ECU, given the used one caused the inactive driver's heated seat to work. 2015 Range Rover Autobiography 4.4 SDV8
Post #598775 25th Jun 2021 6:33pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I`m in Thumbs Up
Post #598779 25th Jun 2021 6:50pm
TDV8 Paul
I’m interested in this as mines not working and the duct is intact so might be worth a go! 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #598784 25th Jun 2021 8:32pm
JNC
The plastic part of the seat back cracks over time. This causes the peltier unit to overheat and burn out.
Until now the only option was either a new complete unit (£280 odd last time I checked) or replace the cell and try to repair the cracked pipe. (I have repaired mine 2 times now with 2 different methods and I suspect it has gone again)
This new kit will replace both for no more than half the price of a new unit.
Post #598787 25th Jun 2021 8:44pm
garyRR
So I'm clear, if it fails, does this stop the ventilated seat back working but not the base?
If I turn on my ventilated seat, I can hear both the fan in the base and In the back run but, don't get any air coming through the perforated leather.
Obviously I do also have an ECU issue if my heated seat started working with a different ECU. I just wonder if the reason I'm not getting the ventilation through the seat back could be caused by something other than the ECU. 2015 Range Rover Autobiography 4.4 SDV8
Post #598796 25th Jun 2021 10:28pm
JNC
If you don't have IID Tool or similar a good test is to feel the fan and put the heat on full.
If it turns off after a few seconds there is a fault. (Usually the seat back ducting cracked causing the cell to overheat)
Now the cooled side has no thermistor so the fan will run regardless of if the cell is working or not.
If the cell has gone it wont produce hot or cold.
If the ducting has split most of the air from the motor will be escaping before it gets to the seat.
Post #598797 25th Jun 2021 10:42pm
garyRR
My car is a 2006/7 3.6 TDV8. I thought those models had heat pads for heating but the fan for cooling? Is that not the case?
Very odd because I now cannot get the heated seat working on the passenger side but, with a change of ECU, the heated seat is working on the driver's side. 2015 Range Rover Autobiography 4.4 SDV8
Post #598803 25th Jun 2021 11:38pm
JNC
As far as I know all L322 Heated & Cooled seats use that system.
The peltier cell can create heat and cold dependant on polarity. So the one unit can do both.
Post #598807 26th Jun 2021 12:27am
t5pete
Put me down please
Post #598823 26th Jun 2021 7:49am
Page 1 of 4 1234>
