![]() | Home > Maintenance & Mods (L322) > Rear door wheel arch seals broken? |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
There is a full length plastic strip with the clips moulded into it, they aren't a lot of money from the dealers but yeah, Sikaflex or 3M VHB tape would do it... |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 959
Looks like the thin plastic strip is still there in the photo - should have fixings on the reverse side that clip into the holes. |
| RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 262
Exact same problem - my clips no longer ‘clip’ at the lower end. I was planning to bodge it with an impact adhesive. 2011MY 4.4TDV8 Autobiography Baltic Blue
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238
As Haylands say, you can use various adhesive tapes, looks like the fastening strip bits may have broken off / perished. Below link is for the fixing strip you MAY need to refit. Different part for left and right doors.
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2770
I recently purchased an assortment of plastic clips hoping to fit individual clips when I get to clean-off all the mud. |
I fixed mine by cutting off the plastic clip strip just clear of the bottom hole then used a fir tree clip to hold the trimmed end of the strip. There's now no plastic strip past the bottom hole but it never held the seal in place anyway. |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
Sorted!
| TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224
I had this, I got a load of fir tree fixings and trimmed them to size- worked perfectly 2009 (2010 MY) 5.0 Supercharged Autobiography
