Home > General > Engine Cleaning
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Engine Cleaning
My 4.2 SC engine is caked in Mud, it's over the pipes, electrics and everything.
I gave it a quick clean with a sponge and low pressure hose carefully aimed at the worst bits yesterday evening, and I managed to cause the Amber Engine Warning light to come on (well I think that was the cause anyway)
I took the car to the dealers today and they cleared the fault and reported that they couldn't find anything wrong.
So how can I clean a very muddy engine without upsetting the ultra sensitive electrics?
Thanks
Justin
Gone - Range Rover Supercharged 2006
Post #59890 11th Apr 2011 8:39pm
interesting question.. Wink ... - .- -.
Post #59893 11th Apr 2011 8:43pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
working by hand and using swizoil(swissvax) products.
they are quite expensive. But I think they are the best on the market.
they have stuff for engine cleaning
And post some pictures how dirty your engine is Very Happy
Post #59904 11th Apr 2011 9:06pm
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
I personaly try to do it by hand starting with some APC and alot of microfibre cloths. As above will always depend how mucky your engine really is.
There's loads of differnt trim dressing to finish it up nicely.
http://gallery.me.com/paul_harland/100010
Range Rover Vogue TD6 2002 "52"
Bonatti Grey
Post #59907 11th Apr 2011 9:10pm
HUGI
about the Swissvax Engine they say:
Quote:
* Waterthinnable Engine Cleaner concentrate enriched with citrus oils
* Allows effortless, effective and thorough but gentle engine cleaning without any negative side-effects neither affecting plastic parts nor electric components
* We recommend the combined use with a Micro Wash microfibre towel and a Swissvax Wheel Brush.
Swissvax Engine is a waterthinnable Engine Cleaner concentrate enriched with citrus oils for the effortless, effective and thorough but gentle engine cleaning without negative side-effects.
In contrary to many other aggressive acid containing engine cleaners, Swissvax Engine neither affects plastic parts nor electric components and therefore is guaranteed safe to use.
Swissvax engine is mixed with water in the correct mixing ratio using the Swissvax Mixing Bottle and is directly sprayed on the surface areas to be cleaned and then left it work for a few minutes. Clean the plain surface areas with a Micro Wash towel and hard to reach areas with a Swissvax Wheel Brush.
I never tried this one but other swissvax products.
Post #59910 11th Apr 2011 9:16pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Not a range rover but on a golf gti i have covered all the electrics with bags etc, got it steam cleaned then sprayed the lot in GT-85, came out great without alot of work. 2004 black Vogue TD6
Post #59911 11th Apr 2011 9:16pm
JustinP
I like the suggestion of bagging up the electric bits, as most of the mud is in hard to reach places. Its only mud no oil, so maybe a pressure washer will shift it rather than a steam cleaner.
Post #59912 11th Apr 2011 9:20pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
Virasol 50-50 mix then hose off no need to pressure wash Far to many gone...
Post #59923 11th Apr 2011 9:45pm
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
may i suggest before anyone ventures into mud or water to try a product called FLUID FILM just google it, as we use this product to spray the engines and electrics on our jetskis. keeps water out and lasts a long time. maybe worth a go. ONE LIFE LIVE IT
Post #59935 11th Apr 2011 10:21pm
JustinP
A quick google of virasol suggests it's a degreaser, I only need to shirt some sandy dirt.
Can you post a link incase I'm looking at the wrong stuff?
Post #59937 11th Apr 2011 10:26pm
i honestly think that nothing would protect the engine bay from the stuff we went into.. Wink
justin, re the pressure washer, it took some of the 'big' muck off but its left a residue which i think only wiping will get it off ..steam cleaning sounds attractive though. ... - .- -.
Post #59951 12th Apr 2011 9:03am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Up here we have had a spate of reported self destructing alternators on Defenders after playing in the mud - after washing, grit has got inside them and then acts like grinding paste so be very careful not to flush dirty water into the area around the alternator. Another place to clean carefully is around the side intakes - best to take off the vent finisher and wash carefully inside the panels to get the crud out so it doesn't become fine sandy dust that gets sucked into your engine 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #59953 12th Apr 2011 9:09am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Think yourself lucky, I remember several hours spent cleaning a Leyland DROPS after playing in the mud. The truck may have been clean, but I was definitely not!! Laughing
Post #59955 12th Apr 2011 9:13am
we had a little dust on our salisbury trip and got the ranges covered in fine dust but i can imagine how dusty the vehicles get in iraq, must be a nightmare cleaning them.. ... - .- -.
Post #59956 12th Apr 2011 9:16am
Tim in Scotland
I hope you had the aircon/ ventilation on recirc and all the windows closed otherwise you will be getting dust blown out at you for ages to come too! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #59957 12th Apr 2011 9:17am
