![]() | Home > Technical (L322) > no gas in aircon |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
i have no gas in my aircon , so does that mean there's a leak or could it be that it hasn't been topped up for a while?... ... - .- -.
when the gas gets low for one reason or an other your air con will not run, this is so you dont screew the compressor, so is your system low or empty, V8 facelift Range Rover Autobiography 22" wheels.
cheers kilovolt |
kwik fit were doing a deal, if they could not improve it by 10% they would not charge you, whip it in there and they will test the system, it must have a leak or some thing was removed and never recharged. V8 facelift Range Rover Autobiography 22" wheels.
bad timing as my son is just changing his employer otherwise he could have done it on the quite..
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
You can buy tjhe gas and do it yourself its easy |
i was toying with that idea ![]() Y. O. L. O. . |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
i would go with kwikfit they said if the cant make it cooler by 10% doesn't cost a thing. Saying that cant be to hard if kwik fit are doing it. |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
I wouldn't bother stan. They sell it halfords for about £40 a tin. It will only put more gas in and what you really need is the old gas taking out and new putting in.
i've had a read on the interweb and i agree going to a garage seems the best as they also [like you say ![]() Y. O. L. O. . |
Are you talking about using the "top up kit"? Even the largest halfords do will only fill the system half full. It also won't evacuate the system thoroughly, lubricate the compressor or remove any contaminents. Then after spending nearly £100 on a couple of the kits from halfords it could all leak out again in a weeks time because you didnt spot a split O-ring. I've never had much success with KwikFit and their re-gas service. Last time I took the P38 there they sucked all the gas out and never put any back in. I pointed this out on the printout they gave me and then actually put some in. There is a guy down here (Melksham) if you fancy a road trip, I've used him on 2 P38s and two freelanders. From re-gassing to replacing whole pipe units. If you suspect a leak he will fill with UV die and go over the car with a UV lamp to pinpoint the leak. Terry Adams - 07919 521 999 ![]() |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
I know most folks don't like to go over a dealer's service reception threshold but the 3 service receptions that I have visited in the last fortnight have been offering a full aircon service for £55. Don't know if this is a nationwide thing or just something local 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
.....and pay for it. |
Stan, your post inspired and reminded me that mine was also empty. I took it in this morning to a body shop on stake hill in Middleton (been there before).
