![]() | Home > Technical (L322) > Coolant haemorrhage lots of drips 2011 l322 tdv8 4.4 |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
I’ve not heard of an oil cooler on the 4.4 leaking like that. Normally it’s oil that leaks out, or the coolant goes into the oil and vice versa.
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
I had my oil cooler replaced last year by a good Indy, book time is 4.5hrs & genuine LR oil cooler was £300 + vat so that gives you a rough idea of basic costs. Anything between £700-£1k should do it comfortably. I think, if you're on a budget, you can buy a pattern oil cooler [Nissen I think] for a few pounds less but that's entirely up to you.
| Chieflongshin Member Since: 17 Mar 2021 Location: Uk Posts: 28
Definitely a bizarre one. I’ll have to look under the engine cover tomorrow and see what I can spot, I wonder if it could be a pipe let go. Engine was running fine up to me noticing, didn’t notice any smoke or smells. I have had one or two whiffs of burnt oil after a long drive but doesn’t seem to have lost any. |
The 'burnt oil smell' may well be a giveaway, mine had been leaking a while I reckon then one day I pulled into a Shell garage to fill up & smoke rising from the engine bay........that ain't good! Oil cooler was goosed, common occurrence apparently.
| mattgage Member Since: 21 Apr 2014 Location: Suffolk Posts: 38
I've had coolant drips in that area - the O rings perish. |
| Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1531
Does the 4.4 have the same coolant hose that runs along the V that the 4.2 S/C Petrol has? Mine failed on that and I had coolant running like your picture.
Well we are in "'lets hope the warranty covers it" territory
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
99% of oil coolers have to be replaced on these at some point.
I'm going for the suck it and get it all done approach yes. I want to forget it for another 100k. |
Well the saga continues.
| Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570
Sounds like you have a decent garage doing the work, as most would just say can't do it without the part!.
| JNC Member Since: 23 Feb 2020 Location: UK Posts: 293
Just thought I would add my story here as it may help.
I’m using a company that have some well known vehicles they’ve created.I’m pleased with their service so far. I’ve been on the end of the “my mate only charges £40ph” from friends but I want to take a heart problem to a cardiologist, not a psychologist so I’ll pay it. |
| All times are GMT |
