Home > Maintenance & Mods (L322) > Compressor oil for new air compressors...
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Does anyone know if the new air compressors for a MY11 4.4TDV8 come pre-filled with compressor oil, or does oil need to be filled on first installation?
Thank you
Post #599096 29th Jun 2021 11:19am
Rambles
Reading manuals and using google, it seems the compressor oil / refrigeration oil is added along with the R134a when the system is being gassed for the first time or whenever the system is drained and regassed
Does that sound right?
PAG 46 is the equivalent of what the workshop recommends as the lubricating oil
Post #599243 30th Jun 2021 1:17pm
ur20v
A Trap
Oil needs to be added, when changing components in an old system, there should be a list of amounts to add especially for large components like the compressor and receiver dry.
It’s a good idea to replace the reciever dryer when opening the system to replace any components. And remember to back the system for 1+ hours to remove moisture or you can have performance issues as the TX valve can ice and internal corrosion can happen. 👍
Post #599259 30th Jun 2021 4:58pm
Rambles
Thank you
What do you mean by “back the system for 1+ hours”?
Post #599306 1st Jul 2021 5:56am
dingg1
He means evacuate
Hth
Post #599308 1st Jul 2021 7:46am
Merchy
As in above post, plus leave vacuum on for an hour to test for any leakage in the system.
Post #599311 1st Jul 2021 8:55am
ur20v
A Trap
Auto spelling correction… ‘back’ was supposed to be vacc, as in vacuum or evacuate 🤷
Post #599341 1st Jul 2021 12:19pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
It seems that everyone (maybe correctly) has decided that the op is talking about Air Conditioning Compressor. My immediate thought was air suspension compressor because that IS an air compressor whereas the a/c compressor is not? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #599354 1st Jul 2021 5:55pm
ur20v
A Trap
It was his second post where he talks about R134a that gives the game away 😇
Post #599358 1st Jul 2021 6:13pm
