Home > Technical (L322) > 2008 tdv8 ignition switch replacement
ianr63
United Kingdom 2007 Range Rover Autobiography Black TDV8 Santorini Black
Hi before i rip all of the dash out please can someone advise how to change the ignition switch / gain access to it ?
RR is a 2008 TDV8 with the ignition switch mounted up on the dash next to the steering wheel.
i have found several threads regarding ignition switch faults but nothing to explain how to get access to the switch.
Post #560262 4th Jul 2020 11:38pm
DrRob
https://www.fullfatrr.com/forum/topic44592...ec5458411f
If you use the Search button in the brown banner just below the right hand image of a RR above it works a treat Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #560274 5th Jul 2020 8:29am
ianr63
Hi Dr Rob thank you, i have managed to change the ignition switch by removing most of the dash, lots of patience required !!!!!!
i coudn't find anything on the forum that helped but i am sure there is somewhere.
photo shows the ignition switch back in position, white cable connector below is twist lock and a fiddle to remove an re fit
photo of ignition barrel removed from switch, right hand side of switch half way down is a sprung retaining clip, depress this to extract from switch housing, access to this is when you have undone the 2 screws retatining the main switch pin connector & relay pin lock.
i will gather more photos later if anyone needs them for information.
Post #560363 6th Jul 2020 11:08am
LiamCuz
England 2009 Range Rover Vogue TDV8 Santorini Black
If you could throw some pics and a how to together that would be brilliant. I tried searching on this forum and all topics I could find were for pre facelift (next to gearstick)
It might be something that I need to do in the future.
Cheers 2009 FFRR 3.6 TDV8
Post #561178 12th Jul 2020 9:00pm
woldsman
United Kingdom 2008 Range Rover Autobiography TDV8 Java Black
hi . I need to replace my ignition switch too . removing the dashboard looks like a daunting task , where do you start ? does the new switch come with new keys or can you still use the current barrel and keys . Thanks for any guidance ( i am new to the forum )
Post #599486 3rd Jul 2021 9:49am
