Home > Maintenance & Mods (L322) > Second Battery Install Help
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi,
I've got 2004 4.4 v8 petrol, and I've installed a second battery in the rear and am wondering which fuse is ignition controlled??
I've plugged the kit (from Luxury Land Rover Upgrades) into the cigar socket fuse (No 71 / Slot 1) in the rear but suddenly wondered if it's ignition controlled (like my Audi) or whether it's constant live?
Thanks for any help Bow down Thumbs Up
Post #599553 3rd Jul 2021 7:02pm
mjdronfield
The sockets are permanently live, until the 2010 facelift, then they are not.....ask me how I know 🤣 ask me if I spent best part of £300 on a cool box I can’t really use. 🤣
I know I could bridge something.....
So you should be fine.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #599555 3rd Jul 2021 7:10pm
As above none of the fuses are ignition controlled but running above the fuse board is a thin green wire which is ignition controlled. Depending on what you want to achieve this wire can be used to trigger a relay, the output of which is then ignition controlled. Thumbs Up
Post #599558 3rd Jul 2021 7:22pm
batfink
I should have said that I’m after an ignition controlled fuse so that I can plug in to a relay, so that the battery isolated when the car isn’t in use.
I think I heard that someone has used the fuel pump fuse, but not 100% sure, Andy if they did if it was right to do so or not.
Cheers
Post #599564 3rd Jul 2021 8:13pm
batfink
I’ll take a look for that green wire tomorrow 👍
Post #599567 3rd Jul 2021 8:38pm
The green wire is actually green / yellow ( Embarassed ) and is in this harness, just find a convenient place to splice into it.
Post #599574 3rd Jul 2021 9:10pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi what fuse does the firm land rover upgrades suggest to use batfink new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #599580 3rd Jul 2021 9:51pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
The simplest and in my opinion the best way to connect a 2nd battery in the rear is by using a cheap voltage sensing relay. Take the live from the big red cable going to the rear fusebox. I would also recommend lifting the loom out of the void to stop any chance of the battery rubbing through any wires. Simple and cheap
https://www.ebay.co.uk/itm/203476554417?ha...SwvYhgsgDQ
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #599598 4th Jul 2021 7:33am
GraemeS
Australia
Yes - replace the appropriate relay in the passenger fuse panel with a link made with 2 spade terminals and appropriate size wire.
Post #599601 4th Jul 2021 8:56am
batfink
Hi Oggy,
They said to use the fifth fuse along but that's for the rear blower, so they must have been using a latter RR and they haven't gotten back to me when I've emailed them.
Post #599649 4th Jul 2021 10:24pm
batfink
Their kit is pretty good and does link to the big red cable at the rear fusebox. It has a relay and the negative goes to the body (after clearing away the paint). I did move the loom off of the floor and moved it to the front of the battery so it won't rub. I also used my Dremmel and removed the captive screws the cable ties were on, which means the battery sits nicely on the floor and all the trim panels go back with no problem.
Here's a picture of the kit (from someone elses youtube channel)
Post #599651 4th Jul 2021 10:29pm
wayneg
The VSR in my link goes between the 2nd battery and the fuse box main feed red wire, similar to your pic. When the car is running the 2nd battery gets charged, when you turn off the engine the 2nd battery is isolated. Fully automatic, no chance of forgetting. The beauty of this is that the charging must be over 13.8v before the switch, not 12v or less with a standard relay. Don't forget a meaty resettable fuse, I can't see one in that pic. I have connected my rear 12v socket directly to the 2nd battery having removed it from the loom 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #599664 5th Jul 2021 12:45am
batfink
So an update on this. I've had Luxury Land Rover Upgrades contact me and they've said that I can splice into the Green cable that goes into the towing connector (white block near the fuse panel on the rear). So I'm assuming that's the same Green cable that was mentioned before.
He's going to send me another cable that will replace the fused cable so I don't need to go to the fuse panel.
For info his website has a few decent bits of kit and he's also said that he's going to be selling plug and play Bluetooth kits for these older RR soon.
Cheers for all the suggestions everyone Thumbs Up Thumbs Up
Post #599761 6th Jul 2021 8:57am
oggy
hi batfink that is sounding a lot better yes i would say that is the one that niceday is talking about does this wire fire up the relay will that still be fused or not new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #599820 6th Jul 2021 6:09pm
batfink
Apparently there’s no need to add a fuse as he said it’s fused upstream from there already.
Post #599821 6th Jul 2021 6:28pm
