![]() | Home > Off Topic > Sash window not raising |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
Is the top sash sliding independently from the bottom. If not then the paint has fused them together, a bread knife sorts that!
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 157 ![]() ![]() |
It’s not the pulley wheel jammed at the top of the frame? |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1090 ![]() ![]() ![]() |
The top sash moves as it should, it’s just the lower sash and the pulley wheels seem ok, you can pull the sash cords inwards and you hear the weights moving.
Apply upward pressure on the sash by hand and gently tap left and right side of the sash near the box using a rubber mallet or palm of your hand. Hopefully it frees and moves up. Do not be tempted to tap the sash up, if it’s single glazed and does not move/free doing that it usually cracks the glass.
Personally I would never tap any of my sashes, some contain the original Georgian glass and glass as it ages becomes very brittle.
Gently tapping with a rubber mallet is an acceptable solution, when serving my apprenticeship 34yrs ago it worked fine and the miserable old git who employed me would have battered me if I broke the glazing! |
In my case it would the mrs who would have a go Range Rover 4.2 Supercharged 2006
Youtube to the rescue ?
Thanks Joe. I’ll get SWMBO to watch the video and then guide me. That way if it ends up going wrong it’s not my fault…… |
Wow that was brutal! I've never had to apply that kind of brute force to any of my windows. I have 7 of them to look after on my grade 2 listed property and most of them are original and in very good condition.
Agree to some extent. The video/s were really to show how the sash windows are all put together... . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
