Home > Maintenance & Mods (L405) > Tyres wearing out on inside of tyres
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Hi has anyone had the problem of the tyres wearing out on the inner side of the tyre tread ?
This is my second set of tyres that have been ruined.
The tyre guy this time I need special Camber bolts to fix this as the car does not have Camber adjustment.
Has anyone ever fitted Camber adjustment bolts and where do I find them.
The tyre guy said the should come in a kit for front and rear wheels.
Post #599217 30th Jun 2021 8:03am
These any good...?
https://www.jgs4x4.co.uk/range-rover-l405-...ntrol-arm/ Pete
-Click here for Thread-
Post #599228 30th Jun 2021 9:52am
jettec
Thanks for posting that I will ask the tyre repair shop if they will work.
Also need a fix for the back wheels as well as these are wearing the quickest when I tow large caravan.
Any more suggestions out there ?
Thank you.
Post #599309 1st Jul 2021 8:10am
pld118
https://www.fullfatrr.com/forum/topic54134.html?highlight=hunter
Post #599464 3rd Jul 2021 5:10am
Rears are adjustable, there are cam bolts on the hub bushes, they are usually very tight and corroded in the UK...
Nose weight of your van will have an effect so balance the van well and measure it... Thumbs Up Pete
Post #599491 3rd Jul 2021 10:49am
DrRob
You need to find a different tyre guy Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #599536 3rd Jul 2021 4:39pm
Ditto ^
Post #599595 4th Jul 2021 1:06am
jettec
Hi could you supply drawing of these hub bushes, as the tyre shop showed me a drawing from the manual the shows Toe/Cam bolts on the lower control arm #5500c that adjusts toe movement on rears and a little bit of camber, but mainly for Toe of rear tyres
Not just Camber adjustment.
Thanks for replies.
Post #599596 4th Jul 2021 2:20am
Sorry getting confused with myself (doesn't take much) that comment was for a L322 not a L405, not a clue what it has at the back...
As has been said above, try somewhere else, if there is no adjustment then it's usually fixed within specifications unless you have damaged suspension components... Pete
Post #599623 4th Jul 2021 4:31pm
jettec
Update managed to get Adjustable upper control rods from supplier. The tyre wear has been an issue from new.
The new rods give plenty of camber now so all fixed.
I guess if I was able to source them they must have known there were issues out there.
Also replaced front upper control arms with adjustable arms from german manufacturer now drive like a dream.
Post #600710 15th Jul 2021 2:00am
GraemeS
Australia
The front upper control arms are available from LR in 3 different lengths but the Meyle adjustable version sounds a much better option.
Post #600713 15th Jul 2021 3:36am
jettec
Yes I bought the meyle arms very nice.
Post #600715 15th Jul 2021 5:49am
