Home > In Car Electronics (L322) > Rattle from front speaker itself - repair or replace? |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
Since my car arrived I’ve had a rattle in the front near side lower speaker. It’s only noticeable with songs with plenty of bass as it’s normally drowned out by the rest of the music. Unfortunately there’s a few songs where it really shows.
5th Jun 2021 8:34pm |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 274 |
Seems to be a common fault, genuine ones on e bay for less than £50 - or I think there is a thread on here about replacing with a generic unit. |
11th Jun 2021 5:00pm |
longi Member Since: 29 Jun 2021 Location: Auckland Posts: 5 |
I had this issue on a 2011 with Logic7, bottom left speaker. Went to the trouble of taking the door card out to see what was causing the rattle. The speaker was broken and would rattle at high volume.
29th Jun 2021 9:52am |
Chapeau! Velo Member Since: 22 Jul 2019 Location: Down South Posts: 115 |
Ive got the same issue and if I’m going to faff with taking the door card off I may as well have a replacement speaker on standby! |
4th Jul 2021 11:30pm |
This really helped me: |
4th Jul 2021 11:35pm |
So I eventually got around to this job this weekend! (My one successful planned job so far!)
17th Oct 2021 1:04pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 189 |
Thanks for the update, I’ve still not managed to get round to doing mine 2007 TDV8 Vogue SE
18th Oct 2021 1:34pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
How odd, took my door panel off this weekend to cure a creaky door speaker cover and also discovered than it wasn't just the panel creaking, the speaker has blown.
18th Oct 2021 1:59pm |
The plastic speaker grille is not removeable. It's attached by what appears to be sonic welding (melting) some trunnions over at the end to secure it. I've used felt tape to lessen mine creaking as it seems to stem from the union between the grille and the inner part of the door Christian. Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
18th Oct 2021 2:02pm |
Urgh… that’s a shame. Looks like I’ll have to do something similar then. I need to sort a couple of other creaks dotted around in a similar fashion.
18th Oct 2021 6:50pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2973 |
I’ve just replaced the big speaker at the bottom of the drivers door on my SC.
18th Oct 2021 7:13pm |
