Home > In Car Electronics (L405) > Postcode issues in Nav…
Marcus
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi All… wonder if anyone else has experienced this Nav issue… sometimes when selecting the postcode option the icon dims once pressed (as if it were working) but then the system freezes… eventually it will return to Home Screen but the post code option always then freezes… lock up the car and try another time and all is well… strange! Did notice the other day that this seemed to coincide with phone not connecting too… most odd. MY15 if that helps…
Post #600555 13th Jul 2021 9:15pm
should'nt happen..is the battery ok? ... - .- -.
Post #600556 13th Jul 2021 9:19pm
Marcus
I think so… I don’t seem to be seeing any warnings or experiencing any other electrical issues… is there a simple way I can check? Also, is there a potential software update I can check for? It does seem random… thanks in advance!
Post #600558 13th Jul 2021 9:39pm
there are no software updates for this problem that i'm aware of but a call to a dealer might help..
the reason i suggested the battery is that if theres not enough juice going to the relevant ecus then it 'could' cause an intermittent fault.
you could try a battery disconnect ..it works on PC's.. Wink ... - .- -.
Post #600560 13th Jul 2021 9:45pm
Marcus
Thanks Stan - much appreciated! New to the forum but the help on hand here is fantastic!
Post #600561 13th Jul 2021 9:56pm
Marcus
Stan - thought that I would post an update... plugged the car into a CTEK recently and got the battery up to the green led...so far the postcode issue seems to have been fixed. It seems you were right! If anyone else experiences weird electrical issues I'd recommend connecting a charger... stop/start worked for the first time too! Thumbs Up
Post #613312 21st Nov 2021 5:42pm
Deffo battery related then sir... The stop-start is the first thing to stop as the battery loses life Thumbs Up
Post #613323 21st Nov 2021 6:15pm
glad its sorted Marcus.. Thumbs Up ... - .- -.
Post #613394 22nd Nov 2021 10:30am
Friendee
Wales
I’m having issues with touch screen but only on sat nav, phone and Audio. Those buttons to the right of the screen light up when pressed but then nothing, and Home Screen shows those affected but not lit up. Did you experience this with your touch screen? Have now replaced both main and secondary batteries after ‘low battery start engine’ warning appeared. I was hoping the battery issue was connected with the touch screen issue as voltage drops can give rise to other malfunctions, but it hasn’t cured the touch screen malfunction.🙈
Did you disconnect your battery before charging?
Post #614006 28th Nov 2021 12:57pm
Marcus
Hi Friendee - no, just connected up the CTEK and tried again once I got the green LED after an overnight charge... I've used the car several times since (connecting back up to the CTEK now and again) and no issues on the nav as reported earlier, the whole system seems more responsive too... it all seems to be behaving itself... I did see your post on the other thread and wondered if you had low battery but now you've replaced them that's unlikely (mind you, I have had duff brand new batteries too)... I would recommend getting it onto a charger though, that'll tell you if you're running out of juice prematurely and if you know you're fully charged then that's at least one variable you can rule out... Thumbs Up
Post #614029 28th Nov 2021 5:05pm
Friendee
Wales
Thanks Marcus
I’m new to the forum, what’s CTEK?
Post #614031 28th Nov 2021 5:16pm
Marcus
Hi Friendee - it is a battery charger manufacturer... I bought one after the reviews on here mentioned that they were pretty good and because Stan mentioned that the intermittent electrical gremlins I was experiencing could be due to low battery. I think most of the range give you a visual set of LEDs showing what cycle they are going through - I bought the MXS 10 but a lot of people rate the MXS 5 too which has similar features but really any decent charger which gives you a 'battery fully charged' indication might help at least rule that problem out.
Post #614045 28th Nov 2021 6:57pm
Friendee
Wales
Will look into that, thanks.
Post #614052 28th Nov 2021 8:09pm
