![]() | Home > Technical (L322) > ZF 5HP24 2002 4.4 V8 173,000 miles |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1056
Nothing to lose, you pretty much found the reason why you were having issues |
| Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570
Have a go |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
RRPhil on here is God when it comes to this gearbox in particular. He will be along shortly I am sure. sadly he has retired from the Gearbox business but is still the font of all knowledge. |
| MrfixitRR Member Since: 13 Jul 2021 Location: Andover Posts: 4
Thanks for the help |
The gearbox cooler is fed by the lower part of the radiator IIRC and gets sludged up. A New radiator is your best bet I reckon. |
You could disconnect the Radiator hoses & try flushing the radiator. See what comes out.
It's gonna be your rad, there pretty cheap and easy to replace I got mine off the bay you have done the hard work.
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1042
Just checking, but was your replacement valve body assembly definitely a ‘350’ model (i.e. 1058 127 350)?
Hi Phil
https://www.ebay.co.uk/itm/Aluminum-Radiat...635-2958-0
| All times are GMT |
