![]() | Home > Maintenance & Mods (L322) > Passenger airbag light on. Error below, please advise |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
The code is for the passenger airbag switch, used to enable/disable the airbag if a rear facing child seat is installed. It will do a check on the airbag system at start up and if it senses an issue with anything in the system it will throw a code.
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
Thanks weejock, very helpful and informative post.
Ok I have done the following,
Ok replaced the passenger airbag switch today after buying from duckworths, and the airbag light went off.
