Home > General > Picking up a 2009 TDV8 3.6 what should i look for
Page 1 of 3 123>
Klunk
Hi,
As above car is a 2009 with 90k miles and FSH.
Understand there are potential turbo frights, how do i check and what else should i look for ?
K
Post #600566 13th Jul 2021 10:41pm
DrRob
Blank the EGRs with an ebay kit on Day 1.
If you get an EML come on then you'll also need the software patch to remove the EML.
This will prolong turbo life by reducing risk of EGR break up and ingest to engine.
I would recommend you use Bodsy and he'll do the lot all in one go. Ian Bodsworth 07770638023. Mobile out of Telford.
Also does Megaflush gearbox oil changes. Get that done too to prolong life.
Trust me. I'm a Dr Thumbs Up Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #600582 14th Jul 2021 7:55am
Klunk
Thanks,
Are these blank able - see conflicting opinions. I know i need to map out once done.
Does the facelift have a DPF if so is that an issue with Blanking ?
In terms of the general vehicle. - rust - arches and boot lid - check suspension raises and lower etc
Check hi and lo ratio
What else?
Does a normal code reader read codes? I.e. torque app and an OBDII reader?
Thanks in advance
K
Post #600591 14th Jul 2021 9:20am
Klunk
In terms of turbo replacement, if it goes south, how much are they to replace?
I know the RR sport needs the body off and is 3.5 k (so i read)
How is the FF ? Can the turbos be replaced via the wheel arches?
K
Post #600592 14th Jul 2021 9:21am
Slow progress
I’m in the same boat as you, from what I’ve read turbo replacement is between £2.5-£3.5k on the FFRR and you’ll get a mix of people quoting for doing in situ and bigger strip down.
Also the other recommendation I’ve had is replace the hoses with silicone ones, I seem to recall they can be sourced via roverlord and probably a fair few others (c.£95).
What I don’t know is if turbos /EGR fail what are chances the engine is destroyed?
Post #600598 14th Jul 2021 9:59am
Sandman77
When viewing, open the rear left cuddy box in the boot area and make sure it is bone dry. Water leaking into this area can cause damage to a lot of electronics which are expensive to repair/replace.
Check all the carpets are dry, if not it could simply be a blocked sunroof drain but if it’s been wet for a while it could lead to further problems.
Post #600616 14th Jul 2021 12:06pm
DrRob
3.6 can be blanked. 4.4 much more difficult and not a DIY job.
Only 4.4 has a DPF standard but a 3.6 might have had a DPF as an OPTION. Get underneath and you'll see it as well as the catalyst. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #600621 14th Jul 2021 1:08pm
DrRob
Check all the rear wheel arches for rot
Check for oil leaks underneath
Look at paper history and invoices backed up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #600622 14th Jul 2021 1:10pm
mjdronfield
I think the facelifted 2010 MY 3.6 had a DPF as standard.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #600635 14th Jul 2021 3:49pm
ur20v
A Trap
Deleted
Post #600644 14th Jul 2021 5:24pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Re DPF, mine is a 2010MY first registered in September 2009 and doesn’t have a DPF.
I’m not sure at what stage they fitted them to the face lifted 3.6 but it wasn’t straight away Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #600648 14th Jul 2021 6:07pm
Slow progress
You forgot;
Counselling services
Breakdown assistance
Wipes for the oil leaks
Comfortable shoes for when you need to walk to the emergency phone
Post #600662 14th Jul 2021 7:36pm
Klunk
Haha thanks all - really helpful and also funny replies Laughing
Post #600677 14th Jul 2021 9:23pm
Sean
England 2007 Range Rover Vogue SE TDV8 Java Black
Just enjoy the car it is really special
Post #600686 14th Jul 2021 9:49pm
Klunk
That’s what i am hoping
The car looks brilliant and I’ve a good chat with the seller, he sounds like a proper gent and the car appears very well serviced and has had some recent repairs so the signs are good.
It’s top spec and looks beautiful.
If i spend 5k over the course of the next 2 or 3 years it’s money well spent IMO
Post #600687 14th Jul 2021 9:52pm
Page 1 of 3 123>
