Home > Technical (L322) > can any one help rear subframe mounts
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi all can you explain for the reason of the 2 8mm bolts coming of the centre bolt . i would like to use it to fix a strap to is this going to be ok thanks oggy
i ask because i have fitted a rear shield to cover rear exhaust box and need to support front edge
up date fixed support brackets today and drilled some holes to take a bit of heat away it does look better than in the pictures
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #600663 14th Jul 2021 7:46pm
The only thing I can think is that I'm pretty sure that part is fixed to the monocoque, if the rest of the cover is fixed to the exhaust you may get NHV transmitted through to the cabin... There again, maybe not...lol.. Can't see why you can't try and see... Thumbs Up Pete
Post #600694 14th Jul 2021 10:46pm
oggy
thanks haylands i have fixed the rear to the under side of tow bar frame tapped in 10mm hols and it needs picking up to the front it does miss the exhaust rear box completely . i have today pick up a hanging both sides from the 8mm bolts on that mount i have also put some rubber bushing in to take out a solid fix bit of movement see how we go if i have any probs i will take my bracket of the bolt wear the exhaust rubbers bolt on thanks oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #600782 15th Jul 2021 7:07pm
Thumbs Up Thumbs Up Pete
Post #600791 15th Jul 2021 8:57pm
oggy
just a up date on the rear box cover
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #600889 16th Jul 2021 7:28pm
