Home > Maintenance & Mods (L322) > 2008 L322 transmission upgrade
Locash84
United States 2008 Range Rover HSE 4.4 V8 Zermatt Silver
Does anyone know if a upgrade to the 6hp28 from the 2010 to 2012 L322 has been tried in a 2006 to 2009? I see the transmissions are very similar. I thought maybe the IIDTool might be able to flash the transmission and ECU. Why thoughts? Thanks.
Post #600725 15th Jul 2021 8:09am
Why would you want to..??
Over your side of the pond you have lots of transmission shops, I'm sure someone over there will do modified/updated parts for that box if you want some, it is used in lots of vehicles...
IMHO reflashing a box is not a good idea unless you have a specific fault.. Thumbs Up Pete
-Click here for Thread-
Post #600740 15th Jul 2021 11:07am
Locash84
Well for some reason there are more available with lower milage and they are almost $1000 cheaper. Thought if it could be swapped it would be a cost effective way to go. Even less expensive then a rebuild.
Post #600818 15th Jul 2021 11:37pm
Pretty sure it will do it, speak to Pat at GAP... Thumbs Up Pete
Post #600820 16th Jul 2021 12:20am
GraemeS
Australia
The canbus changed for MY10. It appears that the original mechatronics unit has to be retained.
Post #600824 16th Jul 2021 1:14am
