|  | Home > Technical (L322) > L322 2004 HDC & LOW RANGE SWITCHES |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626      |
 I had the HDC and LR PCB re-attached on the gear selector trim a few months ago as all the retaining screws' threads had fallen apart.
|  21st Jun 2021 5:58pm |
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238      | Opening up the centre console is not as bad as you may think, I followed the below excellent thread to change my ignition switch, so the video just about covers what you may need to do. If you can't get the bits there are some good condition used parts around, just a case of a good web search. A complete panel with switches is easy to source. Quite a simple swap.
|  21st Jun 2021 6:16pm |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626      | Thank you for the encouragement, sir! Now, I could certainly combine taking apart of the...bridge telegraph with replacing the cubby box gas struts, perhaps killing two birds with one stone or...more likely doubling my job list in an instant. Boy I hate messing with interior trim and panels  | ||
|  21st Jun 2021 6:36pm |
 Got incredibly lucky this afternoon to spot this little b@stard in the chair's rail!!!
|  17th Jul 2021 4:27pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | Sorted. I’m never keen on garages doing stuff on my car. They just don’t treat it as I would.
|  17th Jul 2021 4:33pm |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626      | True! But I can't fault them as they didn't quite expect the retaining setup i had in place at the time. I should have removed the piece myself but quite frankly wanted to keep my social distancing. Chalk it up to COVID.
|  17th Jul 2021 4:37pm |
| Posting Rules
 Can't fault them though, should have removed it myself...
 Central piece swap is as far as I'm comfortable going unless threatened at gunpoint
