Home > Maintenance & Mods (L322) > Air con |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
air con looses gases after a while and i would certainly start with a regas and go from there. ... - .- -.
18th Jul 2021 10:38am |
rangemad Member Since: 17 Apr 2017 Location: leicestershire Posts: 8 |
Thanks for reply
18th Jul 2021 10:41am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1141 |
Definitely sounds like you have lost SOME gas. Before having it re-gassed, ask them to wave a detector 'sniffer' around the system to see if they can find a leak. Also, you can buy a detector for R134a for around £24 |
18th Jul 2021 10:48am |
Main point is can you find a leak, if so then the system has to have the remaining gas recovered, system fixed, pressure tested and then re-gassed.
18th Jul 2021 10:55am |
Thanks for all the advice 👍 |
18th Jul 2021 11:08am |
i believe kwik fit and maybe others sell a regas with a 'if its not colder you get your money back' guarantee...worth exploring.. ... - .- -.
18th Jul 2021 11:11am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
Or if it’s not that, have a read here....
18th Jul 2021 1:04pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4228 |
Either a re gas needed but my money is on a new compressor. You have the classic symptoms of it 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Jul 2021 1:14pm |
