Home > Technical (L322) > 4.4 TDV8 Plenum
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
4.4 TDV8 Plenum
Looking for some thoughts on this. Does this plenum look split? I can get my fingernail in the gap but not 100% sure it’s actually split or not. Let me know your thoughts.
 2011 TDV8 Vogue SE
Post #601722 24th Jul 2021 6:54pm
Baltic Blue
Have you cleaned it ?
It will have traces of black oily soot if it is split.
Wipe around the seam with a piece of white tissue or kitchen roll.
Post #601724 24th Jul 2021 7:36pm
dennij
Hi Mike, it had a misting of oil prior to me wiping it down and the misting leaves a deposit on the oil filter cover which I would expect if air was being blown out if the seam 2011 TDV8 Vogue SE
Post #601725 24th Jul 2021 7:39pm
Baltic Blue
High pressure smoke test is the only way to be 100% sure, but I suspect it is split from your reply.
When I was compiling the 4.4 tdV8 fault log, several were reported to have failed , always splits along the seam.
Post #601726 24th Jul 2021 7:45pm
dennij
It would make sense Mike I think I have the one Range Rover that is plagued by all the faults currently on your list Big Cry 2011 TDV8 Vogue SE
Post #601728 24th Jul 2021 8:05pm
DrRob
Might be one of the factors causing your issues....worth making sure Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #601732 24th Jul 2021 9:49pm
Unfortunately its quite common... But at least its easy to replace unlike the 3.0 Rolling Eyes
Post #601738 25th Jul 2021 12:13am
DrRob
Craig - what symptoms would this issue cause? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #601755 25th Jul 2021 9:27am
Baltic Blue
Rob,
I logged several in the fault log and they all reported very similar symptoms to split hoses.
Restricted Performance under load was very common plus usual DPF soot filling up rapidly .
Post #601758 25th Jul 2021 9:44am
Mike answered it for me DrRob… Bow down Thumbs Up
Post #601762 25th Jul 2021 10:19am
dennij
Many thanks for all the responses gents, much appreciated. I'll order up a new plenum and get that fitted hopefully this weekend. I did have a high pressure smoke test carried out some time ago (or at least that is what it was booked in for), no leaks were found during the test, however, the passenger side inlet manifold was replaced as they suspected it was cracked. 2011 TDV8 Vogue SE
Post #601828 26th Jul 2021 9:16am
DrRob
Mine does not have that sort of split in it. Checked yesterday when cleaning MAP Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #602277 30th Jul 2021 11:00am
klj
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Hi all. Had a split appear in mine , luckily on the top. Used a good quality epoxy resin to seal temporarily . It is still there and working months later . Must get that new plenum ordered.... ----------------
2010 RR tdv8 3.6 ( gone but not forgotten ...)
2012 RR tdv8 4.4
2004 RR 4.4 V8 (M62) -gone but not forgotten (sob)
1998 P38 RR - least said the better
2009 BMW 7 Series 3.0d
Various motor cycles - BMW GS
1998 Jag XKr 4.0 V8
Post #606707 17th Sep 2021 11:00pm
dennij
@kij
If yours is holding then I would carry on with it until it decides to split again as you won’t get much change out of £500 if you want a new genuine replacement 2011 TDV8 Vogue SE
Post #606744 18th Sep 2021 4:38pm
