![]() | Home > In Car Electronics (L405) > Waze/Google Maps does not speak directions? |
| jvasquez8 Member Since: 14 Feb 2021 Location: Arlington, VA Posts: 11
Hello all,
Bummer,
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
they are having the same problems on the RRS forum... ... - .- -.
| Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 236
It seems to vary, in the past anything from three to seven a year. 21A was released in May, so hopefully we get one with a fix for this issue before the end of summer (but knowing JLR, don't hold your breath) |
Thanks for the updates. I'll try to be patient..
| adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884
The bulletin about it on TOPIx is SSM75415 - InControl Touch Pro - Post 21A Update Apple Carplay Navigation Voice Guidance Not Heard
| whippetman Member Since: 14 Sep 2011 Location: Somerset Posts: 60 |
And Discovery 5 |
All the models affected by this are:
| Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 798
I’m unsure if this is helpful as an alternative? I use the TomTom app on my phone with Apple CarPlay and it works fine on my MY19. The subscription is only about £20 per annum. Much better than the RR sat nav, and includes speed cameras, traffic info, re-routing etc. MY23 D350 HSE
| philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527
Yep, my Jag is the same. Madness! |
Yes, our other car, the I-pace, behaves the same way. One solution that works for both cars is, while using navigation, to switch the audio source to radio for a few seconds and then back to CarPlay and this restores the audio guidance, for Waze, at least… |
| Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 494
And the other bug in the latest release is the car pitch attitude in the 4x4 menu being inverted. I.e. when the car is going up a slope it shows it going down.
Thank You. This works for me until the permanent fix is released. Here are the step by step I gave my wife as well. I hope this helps for others. Additionally, I use a wireless Carplay adapter (I've tested and used CPlay2Air and CarlinKit. I use CPlay2Air as it boots faster) and it works fine there too. 1) Wait for System to boot. 2) Carplay must have started before proceeding. 3) On the upper screen on CarPlay, press the LandRover Icon 4) Choose Source of Radio 5) Wait 5 seconds 6) Choose Source as CarPlay 7) Verify Waze voice directions are working 9) Move on Thanks again!! |
One easier way to switch audio source is by using the lower screen. Tap the two bars ( = ) in the mid upper part of that screen and choose source. |
