![]() | Home > Maintenance & Mods (L322) > At my whit's end trying to solve this :-( Loud noise |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
Without knowing the engine, the description sounds very similar to a delaminating turbo to i/c hose on a TD5 whereby the inner wall of the hose is flapping partly or sometimes fully blocking the hose. |
K3YHL Member Since: 24 Mar 2019 Location: Halifax Posts: 7 ![]() ![]() |
Thanks for the reply, The turbo hose was replaced with an OEM item a couple of years ago. The Hose had come off where it attaches to the intercooler which did cause loss of power and black smoke but no bad noises. Also if it had done this again it would be a permanent issue. The motor can go 20 miles before it starts clanking away! |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
I would still check hoses for turbo make sure they are not collapsing under load. This could cause the turbo veins to wobble and they will eventually disintegrate.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8749 ![]() ![]() ![]() |
You can get a loud metallic tapping from a faulty diesel injector.
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 ![]() ![]() ![]() |
Not sure I would trust the icarsoft dongle, black smoke under load would indicate turbo failure, loss of pressure or over-fuelling. I would certainly check the fuel injectors, and issue here and you could be getting 'engine knock' under load due to the miss timing of the combustion process...that would be my best guess as to what the noise is. I would pull the injectors and look if the body is cracked, it can happen with age.
Thanks for all the advice, have just done my back in working on my lads TT so cant do much at the moment.
Remember
Turbo failure doesn't tend to be intermittent |
Just watched this video and the noise is very similar but would a worn big end bearing cause lack of power and black smoke?
and be intermittent |
Very much doubt it, maybe an idea to get a mechanic to diagnose what's wrong rather than upset yourself by lots of guessing...!! |
good advice from Heylands! 2012 Vogue 4.4 TDV8 - Current
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1400 ![]() ![]() |
Valve issue touching piston crown, now and again? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
I see you're in Halifax. I would take it to Joe at JAS Land Rover nr York.
