![]() | Home > General (L405) > New seats quite firm...... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
sitting on very big wallet? |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
You could try a seating position which reduces the weight on that area, by tilting the seat back a bit and raising the front of the seat swab so as to support the underside of the thighs more. If you are tall consider also adjusting the seat base forward. Vogue seats are a bit firmer than SE/AB as they don't have semi-aniline leather, but they should still be comfortable on long journeys if the seat is set up right for you. Only Range Rovers since 1988 |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
That Wallet is now empty Stan!!! lol
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802 ![]() ![]() |
In most cars the seats need a bit of lumbar but in this one I’ve got it wound right back. I found moving it to the lowest position and then fully back stopped me feeling it in the lower seat back. As has been said, try changing the seat tilt and backrest angle. Part of the problem is there is so much adjustment, it’s easy to get it not quite right. MY23 Panamera E-Hybrid
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2709 ![]() ![]() ![]() |
Then you get it just right, forget to save the setting then the long haired general flounces in, changes it about and your back to square 1. |
ha ha ha spot on Mr Tee.......the missus keys on her Boxster are aligned to a seat position, and I keep picking up her key!! Now Ive got a gold keyring and silver one so I know!! lol
I’ve got memory 1 and 2 set up for me, just in case someone changes it…..but it’s more for when it’s in the dealership as we’ve had memory seats on both bars for long enough for there not to be any overwriting! MY23 Panamera E-Hybrid
ilard Member Since: 21 Oct 2012 Location: London Posts: 713 ![]() ![]() |
I’ve done some pretty epic long journeys and no bum pain from the fatty. I’d fiddle with the base seat angle and such. Or get a new coccyx. Land Rover probably sell them branded for double. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Hi. I have found that if I have the seat swab adjusted to far forwards it exposes part of the seat base structure between the base and seat back and you end up sitting on it.
deansmith Member Since: 17 Oct 2017 Location: Hertfordshire Posts: 88 ![]() ![]() ![]() |
As above. I found the same, but adjusting the seat base rearwards (despite being 6ft2) has helped hugely with numb-bum! |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 354 ![]() ![]() ![]() |
I can last about an hour and half then my rear becomes numb. Oddly, never had this issue in the 322 I owned. |
I just returned from a 2000 mile European road trip, with in-car hours extended by insane Eurotunnel waiting times, and I can safely say my derrière was the least of my worries. Positively pampered, really. Here it is in action in Zurich. I cannot, however, recommend my dietician.
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 ![]() ![]() ![]() |
for me, tilting the seat base back made a big difference. It pushes nicely on my thighs with less pressure on lower back. |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 834 ![]() ![]() ![]() |
I got rid of my 2016/66 Autobiography solely because I found the seats very uncomfortable on long journeys.
