Home > Technical (L322) > Charging, Discharging, Starting Help! FIXED
Tattiepicker
United Kingdom 2011 Range Rover Vogue TDV8 Mariana Black
B1087-54 (2F) LIN bus A - System programming failure - missing calibration
Did you manage to fix this code? I just had my air con serviced and this close is apparently holding out the A/C system from working. Going by the manual 5 motors are the Lin bus input to the ATC module.
Post #602345 31st Jul 2021 12:01am
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
Means one or more stepper motor's gone.
Can you post the complete output? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #602355 31st Jul 2021 8:59am
Tattiepicker
Not sure what you mean by the complete output? I have the gap iid tool if that can be used to diagnose which ones are faulty.
Post #602358 31st Jul 2021 10:10am
ffrr14
yes you will need an output from the IID tool. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #602448 31st Jul 2021 11:55pm
ffrr14
ffrr14 wrote:
It is dropping right
The second battery is recent, but the noise pre dates it.
I will have to do some old fashioned probing the long weekend.
R1 is glove compartment and corresponding in the rear is during sleep, any ideas?
Thank you
Is it possible for R1 to get stuck?? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #603961 16th Aug 2021 10:32pm
GraemeS
Australia
Are you thinking that the heat would be from the contacts or from the coil if the contacts are stuck closed? There's no feed-back from the contacts to the coil otherwise the coil would always be energised without any way to release the contacts.
Post #603970 17th Aug 2021 2:27am
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Have you got an interior light coming on due to badly a adjusted micro switch? Had that one, took me ages to realise the system did not shut down, kept cycling. It was in the glovebox which had dropped out of the track one side.
Post #604026 17th Aug 2021 7:18pm
s.ozer1991
Turkey 2010 Range Rover Vogue TDV8 Nara Bronze
Dear friens,
I have same problem with hvac like as below. Does this mean that i have to change all damper motors which shown on error list?
Post #654994 28th Jan 2023 7:54pm
s.ozer1991
I solved some of problems with removing HVAC. plug off all sockets and then plug in. There was probably loose contact. And after this process, problems has been solved.
If somebody encounters that kind of wide problem, they can focus on HVAC and it’s sockets first.
Post #658984 9th Mar 2023 8:08pm
Well done on the fix... Thumbs Up Pete
-Click here for Thread-
Post #659003 9th Mar 2023 10:59pm
TomC-RRV8
United Kingdom 2012 Range Rover Vogue SE TDV8 Galway Green
I have AC that is very inconsistent in its delivery and have the below fault code:
B1087-54 (2F) LIN bus A - System programming failure - missing calibration.
I have this issue, is it a case of something needing to be recalibrate or replaced. My thinking is the interior ambient temperature sensor. Or as suggested above is it a case of me just needing to unplug the HVAC connectors and check their connections?
Many thanks for any advice. Current
2011 4.4TDV8 VSE Galway Green
1973 Rolls Royce Shadow 1 Brewster Green
1972 MGBGT Sage Green
Gone
2004 Discovery Landmark 2.5D
2003 Freelander TD4 SE
Post #697502 6th Aug 2024 6:19pm
