Home > General > Long term admirer, first time purchaser |
benb91 Member Since: 30 Jul 2021 Location: Kent Posts: 29 |
Hi all,
30th Jul 2021 4:15pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7623 |
Welcome.
30th Jul 2021 7:00pm |
Check the spare... probably the same wheel it had when new.....
30th Jul 2021 9:39pm |
ilard Member Since: 21 Oct 2012 Location: London Posts: 698 |
I’m kind of not feeling it. The wheels are absurd to my eyes. I wonder if going for a slightly older vehicle at the same price might result in a more authentic and satisfying experience. But specific to the ad, there’s not enough details to form a full opinion, as I’d need to know number of owners and details of service history just for starters.
30th Jul 2021 11:10pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4218 |
With a predicted mileage of less than 5K a year I would avoid a 4.4 tdv8 with its DPF. The DPF won’t thank you for lots of short journeys. If you’re just doing long journeys then fine
31st Jul 2021 8:17am |
I ran a 3.0 TDV6 RRS for 9 years from new doing 37k miles and I only got a DPF amber warning maybe twice and it regened fine. I did need the turbo actuator replacing in year four. After that I switched to premium diesel and then later in its life I started using Archoil diesel additive. It ran so sweetly. So you can run a diesel on low milage but take precautions, I would say, to minimise the risk of issues. Taking it for a good blast every couple of weeks is also recommended! L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
31st Jul 2021 11:04am |
Thanks all.
31st Jul 2021 2:13pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1111 |
I like the wheels but I would check that they have the correct load rating, many aftermarket wheels don't. I think they should be at least 940kg per wheel. |
1st Aug 2021 9:48am |
Tomgc61 Member Since: 12 Oct 2018 Location: Staffordshire Posts: 10 |
Interested to see the comments particularly about the 3.6 over 4.4 for shorter mileages/journeys.
1st Aug 2021 11:08am |
LandyGee Member Since: 11 Sep 2021 Location: Ka7 Posts: 26 |
Thats an interesting thread.. Was looking at a 3.6 but recently been put off after hearing about potential turbo issues with them. Therefore was thinking of increasing budget and going for a 4.4. However, im only doing 12 miles in each direction every day for work. Would you therefore suggest the 3.6 is better for that kind of commuting? (24 miles a day) Cheers! |
17th Sep 2021 11:49am |
Chapeau! Velo Member Since: 22 Jul 2019 Location: Down South Posts: 115 |
Unless the 12 miles includes a fast road that gets the engine up to temp and exercises the turbos, you might want to look at a petrol! The MPG in my 3.6 drops to very low 20s if just knocking around in short trips like that. |
17th Sep 2021 12:11pm |
3.6 better…..? Not in my mind…. I’ve done 2500 miles in 2 years in my 4.4. No issues, just make sure you give it a good blast out and the odd longer run for the DPF to regenerate.
17th Sep 2021 12:13pm |
Thats re-assuring to hear!
17th Sep 2021 12:34pm |
How has your 4.4 been over the last few years? What you suggest are the main issues I should look out for when buying / maintaining? Many thanks! G |
19th Sep 2021 9:38am |
