![]() | Home > Technical (L322) > Transmission in 3rd Gear but dash and stick in Park |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8793 ![]() ![]() ![]() |
Can't say I've ever disconnected the battery when checking fuses, never had a problem...
Dughall Member Since: 05 Mar 2021 Location: Scotland Posts: 15 ![]() ![]() ![]() |
Thanks Pete - as i pulled out every single one in every single fuse box this is going to be fun!
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Gear selector indicator switch could be giving out the wrong signal. Try operating the gear selector back and to through all positions several times, also try putting the gear lever in the semi manual mode and moving it back and to ( if same as my 2006 ) see if it changes? Quick cheap test.
Thanks Merchy - tried that. Even took the centre console apart to make sure the gear stick was pulling on the cable when moving.
Just in case you do not have a car manual to hand for the fuses / relays, this may help for the correct locations
Just look for ones near a space with no fuse then try to identify the hole and the fuses either side, you maybe able to tell from the workshop manual which one should have the fuse....
Cheers Merchy - This page was what got me into this trouble in the 1st place |
I now take a picture of the fuses before I start pulling them as I've never done it wrong.... |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 825 ![]() ![]() ![]() |
like to have seen that RR 2005 4.4 petrol
I can just see the fuses all laid out pretty! |
Anyways...
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
What happens if you put the car in neutral rather then park? The car will still start with the selector in neutral so might be worth seeing it that will allow it to start.
