![]() | Home > Maintenance & Mods (L405) > Adding Timed/Remote Climate to 2017 model - it can be done |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35723 ![]() ![]() |
put into the wiki next to the 2014 version..thanks. |
spbee Member Since: 25 Jul 2021 Location: Cumbria Posts: 34 ![]() |
'Antenna for receiver (a glass mount 433MHZ antenna with Fakra I type connector will work)'
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 234 ![]() ![]() |
Unfortunately I can't remember where I got the antenna from. It doesn't need to be a type I connector, a type Z (universal) will also do the job. I used a type I as I wanted to to match the connector on the receiver.
great TYVM |
Last question i promise!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16353 ![]() ![]() ![]() |
Connector body is Landrover part no YPC915820, it is made by TE Connectivity (Tyco) I think part number 1355082-3 but most suppliers seem to only do them with minimum order 1000+ The connector inserts I used were ones I had at work that fitted, I believe the Tyco part number for these is 5-928999-5 for wire size 0.25-0.35mm2 or 5-963715-5 for wire 0.3-0.5mm2 |
brilliant thanks for your help.
All done and tested on my 2015 |
this also works for pre 2017 vehicles |
JoeDoyle Member Since: 08 Aug 2024 Location: Eastbourne Posts: 8 ![]() ![]() ![]() |
The power feed was tapped from the FFBH supply on the FFBH harness with a separate fuse. As I had a contact insert I fitted this to the socket on the vehicle loom for the receiver data connection, this could also be tapped into the FFBH harness.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1756 ![]() ![]() ![]() |
I can’t be the only one wondering: what’s the budget for all the bits to do this, please? |
For the L405 up to 2017 model year with the Eberspächer FFBH
Really hard to find wiring diagram for retrofit, not even the reciever plug is wired correctly. I copied the same wiring as webasto for remote plug.
