![]() | Home > Maintenance & Mods (L322) > Not quite the Amoco Cadiz UPDATE.... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8815 ![]() ![]() ![]() |
Went out for a walk an hour ago to find this in front of fatty....
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
looks nasty Pete...i hope its not to much of a problem... ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Best wishes Pete…. on the bright side, front subframe won’t go rusty.
It never ceases to amase me how wrong I can be sometimes....
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 455 ![]() ![]() |
Good luck, Pete!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
I don't think they tell you oil is low. Relies on owner checking weekly... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I thought they did, seems weird they tell you of low fluid in the coolant, washers & brake fluid, yet you have an electronic dip stick and they don't tell you of low engine oil... |
Pumps removed...
All back together, no leaks from anywhere and it runs 100% so looks like whatever caused it... faulty part, bolt or spanner work hasn't done any lasting damage...
Great. news Pete and hopefully the 24 hr weather forecast will at least help clean up your drive.
Cheers Mike, drive is going next year anyway, fatty is too fat for it and it's nearly like off roading driving on it...!! Pete
Actually had to take the rack 99% of the way out anyway, both trackrods off, pipes off, column off and then unbolted it and laid it down, it's at the bottom of the last pic, it should be vertical in front of the front pump... could have pulled it out but there was then enough room to get the drill in to sort the broken bolt...
