![]() | Home > Technical (L322) > Starting Issue |
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804
It's a fairly common problem with the ignition switch, can either be solved by cleaning out the switch or replacing it.
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238
Had the same, intermittent start failures with no cranking, slowly got worse, till I fitted a new ignition switch.
| batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 207
Brilliant, thanks and typical that it did it on holiday for the first time 🤣 |
Hi batfink, mine went on for weeks, started out as the odd random failure, and got to the point where it would take up to ten attempts to start. I had ignored it as it was the middle of winter, so when I finally changed mine it was outside at minus 4 degrees C, not funny without gloves on! so you may get away with it until you finish your holidays. Fingers crossed.
As long as it eventually gets going then I’m fine with that and will fix it when I get back home in a few days as I’ve no told with me at all. |
One little tip, near the end with my old faulty switch, when I turned the key against the spring return for cranking, instead of starting I got low volume little electronic beeps, sounded like they came from the centre console, which was rather strange, key out / back in and several attempts later it would start, never heard then again after changing the switch.
So, I got a replacement switch from Duckworths and installed it after the holiday and it had been good since then.
All I can think of at the moment is to check all the battery / earth connections for tightness and / or corrosion and go from there. Assuming that the battery is ok.
Thanks Merchy, I'll check the connections and see if anything is amiss. |
So I checked all cables were tight today and they were all good. Thought I'd get in the car and see about starting it up afterwards....didn't start. Same thing as before everything looks good, I hear the click as the key goes into the ignition switch, turn to position 1 steering column comes out and all lights go on and off as they should. Move to position 2 nothing.
So I got the inhibitor switch out this weekend.....what a |
