![]() | Home > Technical (L322) > Question |
| A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 159
Today a strange thing happens.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
First thing to check is battery voltage.... Pete
The battery is very good |
That's a shame, it's the usual suspect, I'm not familiar with that box so can't help, you may get more replies if you edit your first post and make the title more relevant to the issue... Good Luck... |
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238
It is possible that you have a fault with the transfer box shift motor, not 100% definite, but may be worth checking with a gearbox specialist. Found some interesting reading in the below links, at least the gearbox itself could well be ok apart from needing an oil / filter change if it has not had one yet.
| All times are GMT |
